Question about Kenwood Heating & Cooling
Kenwood Model No. 580.72059200
What is the btu?
AC stopped working - only flashes "PF" now.
I found the instructions call 1800 322 3848... My just said the same thing
Sep 10, 2012 | Kenwood PAC C130EK 13000 BTU Portable Room...
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Do you know the btu rating for Teledyne Laars Mark V
All heaters have a data plate. Often the model # is the BTU's. For example, H400 is a 400,000 BTU output. The plate is on the inner firewall. All heater have different BTU's.
Aug 22, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Need information on the btu
Hey, Back -on line , & the answer to your question is ...go to webpage or type in whirlpool model window unit mod acq189! This equals to 17,800 btu 15 amps 220 volts 3 speed.
Jan 08, 2009 | Whirlpool Heating & Cooling
Kenwood kvt 717 dvd
I think this may be it, here: http://www.partstore.com/Part/Kenwood/Kenwood/KVT717DVD/Kenwood/Kenwood/J84015005/New.aspx If not, do a search for your model number on the same site. They have over 100 replacement parts for that model.
Jul 13, 2007 | Kenwood KVT-717DVD Car DVD Player
Heating & Cooling Logo
18 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
