Question about Logitech Televison & Video
Euromot 200 gxt
Replacement of SKX2HDW battery
My midland gxt xtra talk will not stay charged.
Failing batteries. Old batteries tend to recharge only partially and discharge rapidly.
Dec 12, 2017 | Midland Radio Communications
Midland gxt 756 new batteries but display is too dim to see? No parts broken or loose connections.
Well, there is nothing to repair. Even if you wanted to replace the LED's you would need to open up the radio and figure it out. There are no repair manuals or parts other than batteries available for the consumer grade radios.
Dec 25, 2016 | Midland Radio Communications
How do you change battery in Midland GTX450
Do you mean the GXT450 model, if so this manual is for the 300 upto the 450 and explains how to remove the batteries or battery pack.
http://www.manualslib.com/manual/103192/Midland-Gxt300.html?page=6#manual
Hope this helps
Jul 14, 2014 | HQRP Battery Replacement Fits Midland...
Ferret 40 ...... is there a breakdown for the carbon pile ?
Ferret Instruments was "bought out" by a company GXT, Inc. I worked there for approx 20 years. They have a interesting carbon pile. Consists of alternate Square and round carbon plates. Try calling 800-627-5655 ext 108 repair or they might have changed it ask for Chris or Evy they run the repair dept.
good luck..
or go online to GXT.com not a great website to deal with but the address is 1310 Higgins Drive, Cheboygan, MI 49721
Oct 21, 2010 | Ferret Instruments Battery Load Tester...
Needing a manual for the GXT 756.
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
The GXT 756 is a variation of the GXT 750, which is covered in this manual here....
http://www.buytwowayradios.com/Products/Midland/manuals/GXT-710-manual.pdf
Oct 16, 2010 | Midland GXT450VP4 (22 Channels) 2-Way...
Hello and Good day, Can you please help me get the manual for the GXT 400 X-Tra Talk? Thanks Emileo
just click on this link.. its a pdf file....
www.buytwowayradios.com/Products/Midland/manuals/GXT-300om.pdf
Jun 22, 2010 | Midland X-TRA TALK GXT400 (7 Channels)...
I need a circuit diagram and service manual for sua3000rmi2u and gxt2-3000rt230 can anyone tell mi where to get it??
You can try Emerson the maker of the GXT, although I do not think they will provide it. If the unit is less than 2 years old it is still under waranty, and they will repair it.
Thanks for using FIxYa, let me know how it goes
Jun 05, 2009 | Liebert UPStation GXT 2U GXT2-1500RT120...
Midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Nov 01, 2008 | Midland Radio Communications
Looking for Service Manuals for the GXT Series
Try this site: http://www.liebert.com/servicesupport_pages/ProductDocumentSelector.aspx
They have a large number of manuals available for download for a variety of UPS systems, including UPStation.
-John
Feb 13, 2008 | Liebert UPStation GXT 2U GXT2-1500RT120...
Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 06, 2007 | Radio Communications
Televison & Video Logo
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
