Question about ASUS KB73211 Wired USB Keyboard OEM
Disable blue french - ASUS KB73211 Wired USB Keyboard OEM
How to delete with a french keyboard
Simply select Shift and Alt at the same time - this allows you to toggle between English and French keyboard.
May 30, 2014 | Dell Inspiron 1525 Laptop Midnight Blue
Keyboard is in french need to change to english
Press Ctrl+Shift at the same time. Toggles the French (blue) keys on & off. I found out after much tedious searching. Hope this helps you!
Nov 25, 2010 | Computers & Internet
How do I activate and use the blue key on my HP laptop?
Keep tapping on F10 key while you start the computer to get to BIOS screen and then press F9 and then F10 to exit out of BIOS.
Feb 06, 2010 | HP Pavilion dv6000z Notebook
How do u wire wire a french heater. brown, blue black wire only
Using a multitester, set it a OHMS 1 x 10. Put one probe (black one) to the metal body of the French Heater, and the other probe (red one) to brown wire first,
then to the black wire. The wire that tested zero pointer
reading is the ground, and this must be connected to
the ground terminal of the plug, while the other two is
for Line 1 and Line 2 of the plug.
Nov 24, 2009 | Herbeau 460330 Luberon - 4603 in French...
How do I shift to the blue key functions on the keyboard
I've run into this a lot myself and personally find it annoying more than useful. While typing, your punctuation keys suddenly switch to their french functions. By defaul, Vista assigns a keyboard shortcut fo changing input languages.
This shortcut is ctrl+shift - a very easy combination to press by mistake. To solve this problem, just press crtl+shift until you're back to english. You can change this shortcut or disable it all together.
Open the control panel then click "change keyboards or other input methods" under "clock, language and region". In the window that pops up, click "change keyboards..." then select the "advanced key settings" tab. This is where you can edit and disable language related shortcuts. To change one, click on the profile and then click "change key sequence". Under "switch keyboard layout", select "unassigned" to disable that shortcut.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
Blue key activation
Ctrl+fn+right Shift. To deactivate, press Ctrl+fn+right Shift twice, meaning Ctrl+fn+right Shift then let go of Shift while still holding Ctrl and fn, then press Shift again.
Jun 06, 2009 | Compaq Presario R3000 Notebook
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
May 28, 2009 | Compaq Presario R3000 Notebook
Need instructions on how to use the phone IN ENGLISH
Press start ---->settings-----> system (inthe buttom of the screen) ----->language----> then disable the french support in the 2 small boxes... the phone will restart with the english lnguage...
good luck
May 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Door alarm
It depends on the model you have.  Look on the door panel and look for the control button that shuts off the alarm.  Press and hold the button 5 to 10 seconds and that should shut it off.  If you don't have that feature, then there's nothing to disable the alarm.
May 04, 2008 | LG LFC25760 French Door Refrigerator
ASUS KB73211 Wired USB Keyboard OEM Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
