Reciever not working it says to go to directtv,com/726
Directtv.com/726
Why are you on here? Call DIRECTV
Aug 16, 2014 | Televison & Video
Buy wired remote for directtv receiver
No wired solutions. However you can purchase an RF remote for one reciever and leave on IR and they will then work independently from one another. You can get the RF remotes on amazon for around 25 dollars.
Dec 20, 2012 | Directv Televison & Video
What is code 726 (appears when trying to scan)
error 726 is Recieved an error response from the DNS server. Incorrect POP server address is set. Incorrect SMTP Server address is set
Feb 14, 2011 | Panasonic DP-C213 Color Copier
Pixelation appears. What could be the problem with the set?
I have had the same problem at times. First try out a dvd or Blu Ray disc to see if you experience the same problem. Also check your connections to make sure they are connected properly.
If the problem is not present when playing a disc then check out your Directtv system. Try resetting your Directtv reciever first. If that doesn't work, check with Directtv to see if they can run diagnostics. It might be your satellite dish or the receiver.
Dec 26, 2010 | Samsung Televison & Video
The code 694 does not looking for the correct code for orion tv, i have dishnetwork
Here are the sat remote codes for Orion and Sansui.
DISH CODES
908, 899, 834, 756, 754, 726, 721, 720, 694, 687, 227, 221, 220.
DIRECTTV CODES
11935, 11929, 11911, 11904, 11463, 11409, 11276, 10842, 10463,
10236, 10179, 10173, 10171, 10165, 10054, 10037, 10002.
I hope this helps you.
Bobya.
Oct 02, 2010 | Televison & Video
I was watching tv and then my tv went blue. Now i have no channels. And can only see a blue screen.
i have directtv i was watching it and the screen went blue the reciever works but still have a blue screen
Jul 03, 2010 | Televison & Video
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can recieve...so the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
Can't hookup this DVD Player to the Directtv HD DVR receiver
red and white leads go from dvd to reciever,yellow goes from dvd to the tv
Apr 30, 2009 | Televison & Video
REMOTE WON'T WORK WITH TV
The problem is the DVR is only programmed using a set amount of codes. They don't update them. If your DVR is a few years older than your TV set, you're out of luck. .
You could contact DirectTV customer service and see if they have a solution in technical support for that tv. It's possible another set of manufacture codes will work with it and tech support has it noted.
Sep 12, 2008 | Tivo DirectTV Remote Remote Control
Dynex tv code
THE CODE FOR DYNEX TV'S USING A DIRECT TV REMOTE IS 10463. THEY ARE AFFILIATED WITH SANSUI. THEY USE THE SAME CODES.
Feb 27, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
