Question about Silverline Windows Lock Slide
Broken glass can you remove the stationary side?
How to replace outside side power mirrors in original housing? 2008 Ford Edge
Google replacement mirror glass for Ford Edge 08.
They make a replacement mirror glass available that uses double sticky tape. This has worked great for me. The heated function still continued to work!! In my case I replaced a scratched mirror leaving the old mirror in place. If yours is broken included is a link for a procedure to replace a broken mirror.
Confirm the dimensions before purchasing. Some car manufactures have more than one design for different model cars same year..
26182860-kzssal3k2qlm4jsc53ab1s2h-2-0.jpg This is an easy repair.
How to Repair and Replace Broken Side Mirror Glass DIY
May 02, 2016 | 2008 Ford Edge SEL
Side stationary window 99 monte carlo need replacement instructional video
Check Youtube for a video. Auto glass replacement - that should dredge up some help. Removing the interior door panel and getting to the window-glass support takes the most time in my experience.
Jan 19, 2015 | Cars & Trucks
How do i remove a rear window
hard top or convertible.?
I guess at hard.
Not side rear. or doors., but rear rear. as in rear view.
rear window. glass out? why not say why so can see JOB ? at hand.
eg: my rear view glass is broken.?
is covered in the FSM, (like all cars made)
the factory service manual. or alldata.com (clone) log in read.
ok ill past the FSM words here.
Stationary Windows Stationary glass is removed and installed using the same procedure as the windshield. Refer to Windshield Glass Removal and Installation. (first hit ,btw)
https://www.youtube.com/watch?v=5dp2VVvPlXc
ever seen a front windshield changed out, sure.
same
best solution is......
Call the same company to come out and point to rear .?
they sell a special tool to get out a window.
it has 2 , "T" handles and rod saw. to cut out the glue/caulk.
the glue comes out more easy on a hot day.
its not really glass, it's an occupant containing device, today.
the best caulk is.
3M 08693 Auto Glass Urethane Windshield Adhesive Cartridge
how is my guess.... on car, and glass and reasons.
Dec 04, 2014 | 1992 Suzuki Swift
My driver side rear window is broken its the stationary on the back door. How hard is it to replace?
Depends on the vehicle but I would recommend safelite or another auto glass specialist.
May 03, 2013 | Cars & Trucks
How do you remove the glass from the side mirror enclosure?
Hi, this mirror glass is held in with plastic tabs, in a circular pattern, on the back side of the mirror.Wearing proper gloves, simply grab the glass behind the black backing, and pull out on it, BE CAREFUL OF BROKEN GLASS. Once the glass is out, remove any wires that may be attached, by simply pulling them off of the connectors, replace the glass, and pop back in.
Sep 21, 2010 | 2001 GMC Yukon XL
Window falls down when i use it
the seat clamps for the window on window arm are stationary and built into bottom of glass... if broken then new piece of glass needs to be purchased... if not then can basically be reseated back in joists... of course this involves taking off the inner door panel and removing the entire system... more than likely be prepared to replace the glass
Jan 06, 2010 | 1999 Pontiac Grand Am GT
How do I remove and install a rear passenger side window (manual) in a 1997 Saturn SL1?The window was smashed, and I need to replace it. Thank you so much for your time and help!
Saturn Coupes/Sedans/Wagons 1991-1998 Repair Guide
Door Glass and Regulator - REMOVAL & INSTALLATION
(see Figures 1, 2, 3 and 4)
  1. Remove the outer door panel assembly. Refer to the sub-procedure under Door Locks, earlier in this section.
  2. For rear doors, loosen the bottom fastener of the rear door stationary window assembly, in order to provide clearance, then apply tape to the lower half of the outboard exposed portion of the stationary window channel. The tape must be applied in order to prevent damage to the paint surface.
  3. Lower the door glass, then use SA9148B, or an equivalent tool, to remove the glass nuts. Push the glass upward and rotate slightly, then remove the glass from the vehicle.
  4. If the regulator is also to be removed, proceed as follows:
    1. Remove the inner door trim panel. Refer to the procedure earlier in this section.
    2. If applicable, unplug the wiring harness from the power regulator.
    3. Except for the rear door, remove the regulator cam bolts.
    4. Drill out the regulator rivets and remove the regulator from the vehicle.
To install:
  1. If removed, install the regulator to the door assembly:
    1. Position the regulator to the door and secure using rivets.
    2. Except for the rear door, install the cam bolts.
    3. If applicable, connect the wiring harness to the regulator.
    4. Install the inner door trim panel to the vehicle.
  2. Install the door glass into the door and over the regulator studs.
  3. Install the glass nuts using tool SA9148B, or equivalent.
  4. Check the door glass for proper operation and alignment.
  5. If necessary, adjust the glass alignment. For rear doors, fore/aft adjustments are made after loosening the B bolts, while in/out adjustments are made when the A bolts are loosened.
  6. Except for the rear doors, glass which is not running parallel to the door header may be adjusted after loosening the inner panel cam attachment bolts and adjusting the cam. If the glass is floating in the opening, lower the glass 3 / 4 downward, loosen the front guide fasteners, push the glass rearward to seat it in the rear channel, then bring the front glass guide back to the front edge of the glass. Apply a light finger pressure on the guide and tighten the fasteners.
  7. Once the glass has been properly adjusted and is operating smoothly, install the outer door panel assembly.
Fig. 1: Remove the glass nuts using a suitable tool-front door shown
Fig. 2: Exploded view of the regulator mounting-except rear door
Fig. 3: Exploded view of the rear door regulator mounting
Fig. 4: Adjustments of rear door glass are made after loosening the A or B bolts
I hope help with this (remember rated this help) Good luck.
Oct 16, 2009 | 1997 Saturn SL
How do you replace a drivers side window on a 1992 Saturn
See Figures 1, 2, 3 and 4
To install:
PICTURES ON NEXT POST!
Oct 13, 2009 | 2000 Saturn Ls 4dr Sedan
How do i remove the inside panel of a nissan titan door
Get a 18V drill with phillips screw extention and start buzzing the screws in the armrest and under out...the glass could be anywhere so wear gloves.
Good Luck
Jun 21, 2009 | 2007 Nissan Titan LE
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Silverline Windows Lock Slide Logo
459 people viewed this question
Top Silverline Windows Baby Gear Experts
Dorel UK
Dorel UK
Are you a Silverline Windows Baby Gear Expert? Answer questions, earn points and help others
