Question about Siemens Washing Machines
Water pump wont turn off to let water in - Siemens Washing Machines
I'm attempting to do a timing belt change on my 2004 Chevy Aveo. The problem is when I took off the old timing belt I forgot to loosen the tension using the water pump. When I tried to install the new...
Yes,there is a special wrench that fits the water pump. You have to loosen bolts on pump and put wrench on pump and turn pump to get belt on. Then tighten pump till marks line up on tensioner,then tighten the pump back down. Be sure to roll the engine around twice and recheck timing marks on crank and cams.
Mar 12, 2015 | 2004 Chevrolet Aveo
El 1997 falcon wont start after changing water pump
Have you disconnected any other wires at the fuse box
May 04, 2014 | 1997 Ford Falcon
Wont start but will turn over
Check wiring, you have accidently knocked something loose. the engine should run even without a water pump.
Nov 07, 2013 | 1993 Mercury Tracer
Wont prime.just moved in house and pump goes to lake.turn it on and it runs but no water.do i have to prime
yes fill it with water from top plug and turn it on and keep adding water til it picks up
Sep 02, 2013 | Myers Pump HJ50S
Pull cord wont pull
ok i assume it is a gas powered pressure washer, if the pull rope wont pull out at all you either have a locked up motor or pump if it is out and wont go back in or recoil then the spring under the engine cover has either broke or come unwound.also if it wont pull out do youhave water applied to pump? if so turn off water and disconnect water hose to relieve pressure and try to pull it then then if it starts then apply water.
Mar 18, 2010 | Garden
I need directions to change my water pump
drain engine coolant.relieve belt tension .and remove the drive belt.remove upper fan shroud.remove fan or fan and clutch assembly.remove water pump pulley and coolant hoses from water pump.remove water pump bolts.then remove pump from engine.pay attention to bolts location because they are different lenghts.clean water pump gasket mounting surface dont scratch .or pump gasket wont seal and leak .apply sealant to water pump bolts.install water pump with new gasket.if gasket paper put a sealant on it.torque water pump bolts to 30 ft lbs.if you got a 2.2L engine torque water pump bolts to 18 ft lbs.install coolant hoses on pump .install water pump pulley.install fan and fan clutch assembly.install the drive belt .and the upper fan shroud.fill the radiator with coolant.then run engine to check for leaks.WARNING AS A SAFETY PRECAUTION REMOVE NEGATIVE BATTERY CABLE SO CAR WONT BE CRANK BY ACCIDENT. ALSOOOO DONT FORGET TO TURN OFF RADIO FIRST BEFORE DISCONNECTING BATTERY SO YOU WONT LOSE YOUR RADIO CODE.
Jun 01, 2009 | 1999 GMC Jimmy
Replaced water pump nd timing belt now car will not turn over to start it trys but wont fully turn over. how do i get it to start
timing is incorrect/usually have to find #1 cyl top dead cent then use camshaft alignment marks and then reinstall belt.
May 08, 2009 | 1994 Volvo 850
New water pump wont start
It could be the crankshaft position sensor located near the crankshaft under you sparkling new water pump. Wires may be disconnected.:) Good Luck
Dec 10, 2008 | 1989 Dodge Raider
Bottom wheel of water pump wont turn, burning belt
The wheel could be stuck but you need to have the water drained out and a mixture of antifreeze to water added to it. Be sure to keep in mind the heater core also has fluid in it and you could damage that also.
Nov 24, 2008 | 1996 Dodge Intrepid
Washing Machines Logo
82 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
