How to find the MAC address of Aztech repeater WL559E
HOW TO DISCONNECT WIRELESS MODE FROM MY AZTECH HW550-3G ROUTER?
You will have to go into the router and turn the wireless off. You will need your ip address of the router and the default userid and password to get into the router. The user manual will give you all that.
Get online and got to www.google.com In the google search box type: "Aztech Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals.
Jun 03, 2012 | Aztech HW550-3G 300Mbps 802.11n Mimo...
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
Aztech DSL 605 EW losing internet connection when I am connecting/enable the wireless connection. Could any one suggest solution? Rgrds
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Computers & Internet
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
I have two Dell 2350 Wireless Routers trying to bridge or repeat
The first router must the root AP and the second should be set to Wireless Repeater. Follow the steps on how to resolve this setup.
1. Get the Wireless MAC Address of the main router. The router has two MAC addresses, one is wired and 1 is wireless. To determine the wireless MAC address, go to Status page of the router, there's a sub tab there for wireless and you'll see the Wireless MAC Address. Take note of it.
2. Access the setup page of the 2nd router. Change the LAN IP address to 192.168.0.2 then save. Power cycle it by just turning it off for 10 seconds then turn it back on. You can now change it to Wireless Repeater and there's an option for you to type the Wireless MAC address of the main AP. Make sure all wireless settings are the same on both routers like SSID, Channel and Encryption Key. Save your changes after that.
3. From your computer, try to ping the 2nd AP which is 192.168.0.2. If it replied back, you're all set.
Good Luck!
Jul 25, 2009 | Computers & Internet
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Hi I Have Problem
Hi Andy,
The WAN port on your Aztech DSL600EW (by default) is configured to be automatically assigned an IP address when connected to a cable modem (Motorola). Connect the WAN port of the Aztech DSL600EW to the Ethernet port of the Motorola, then configure the Aztech for wireless connectivity to your laptop as per the manual instructions.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
