Question about MagnaFlow 2004 Hyundai Santa Fe - 2.4L 4-cyl. engine, with federal emissions system - Catalytic Converters
Ac clutch failure - MagnaFlow 2004 Hyundai Santa Fe - 2.4L 4-cyl. engine, with federal emissions system - Catalytic Converters
2008 Suzuki SX4 AC Not working
he opened hood saw the clutch disengaged.
so he connected a voltmater to clutch coil pins, its 12vdc
he is right.
no, its 0v. he is wrong.
if 0v that the THE AMP logic module shutting it down on purpose
so you dont wreck it, it has self protections.
one is the hi/low switch, freon too much or too little.
want to guess or test.
we can find all 7 ways, to cause (or more) the AMP to shut down.
its not hard at all with a $10 volt meter..
ask.
Jul 16, 2014 | 2008 Suzuki SX4
2002-v-6,sonata,72,000miles,was told the ac clutch frooze
the ac clutch will quit working if the refrigerant pressure drops too low ... or if the pressure sending switch is bad or if the wire to the clcutch is broken .. the word "frozen" usually means it cant be turned (not that it just doesnt turn) ... if you cant turn the unengaged clutch then thats a compressor failure ... that may in turn damage the clutch as it slips trying to turn the frozen compressor .. if the compressor can be turned freely by hand then thats not the problem .. if the clutch is simply not being turned on then usually thats just low refregerant or a blown fuse, bad relay or bad low pressure switdh . once in a while there might be an open winding on the clutch or a broken wire going to it .. they cant check refrigerant pressure without first getting the clutch to work ... so its possible to jump power directly to the clutch .. it will usually operate and gauges applied to the air conditioner might show the pressure to drop very low .. that would normally turn off the clutch ... just checking for leaks and recharging often is all that is needed ..
Jun 30, 2010 | Hyundai Motor 2002 Sonata
A/C blows hot air. 2004 Corolla SE
You may need to recharge your AC. The AC clutch relay seems to be a high failure item for this car. You can test by swapping relays under the hood. The AC clutch relay is located next to the negative battery post in the fuse box under the hood on the driver's side fender. It is the smaller relay marked "M/G CLT". This is available from Rockauto.com, $11.
Jun 14, 2009 | 2004 Toyota Corolla
Ac not throwing sufficient cold air
I would try recharging the system. if the recharge doesn't produce could air, this will confirm a compressor failure.Inspect the clutch function. the AC clutch should click when it is engaging the compressors actions.
May 28, 2009 | 1999 Honda Civic
Air condition
You either have a bad AC magnet clutch relay or a bad AC revolution sensor. I'd replace the relay first. Common failure.
Aug 03, 2008 | 2002 Toyota Celica
2003 Dodge Durango A/C started to smoke
There are a lot of variables with A/C concerns. Without being able to answer these, the smoke you saw was originating from the clutch? If so, can you see any kind of oil seeping from the seal behind it? You might also look for oil stains on the hood blanket above the compressor. If there is oil present, you may have a seal leaking causing premature clutch failure. Since you were in traffic at a stop, you might want to check the condensor and the radiator for any kind of obstruction. Also that the fan is coming on when the pressure starts to rise. If you have an oil leak it might be a good time to replace the compressor. If not, it could be just an early clutch and bearing failure. Also, don't forget to check the belt for overheat damage.
Jul 25, 2008 | 2003 Dodge Durango
MagnaFlow 2004 Hyundai Santa Fe - 2.4L 4-cyl. engine, with federal emissions system - Catalytic Converters Logo
Top MagnaFlow Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a MagnaFlow Hardware and Accessory Expert? Answer questions, earn points and help others
