Question about Lands Phones
Base kx-tga401 Base no power. check telephone line.
3 Suggested Answers
SOURCE: I have the kx-tg 4500
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Posted on Oct 01, 2009
jyackle5
  • 8197 Answers
SOURCE: Just bought a DECT1588 seies
HAve you tried to plug in to a difrent plug to see if you have power. Also you do not need Surge Bar for the phone.
Posted on Jan 22, 2010
I need a user manual for Pansonic model KX-TGF370.
Most Panasonic manuals are available on the product page or by searching here: http://shop.panasonic.com/support . The base has the model number KX-TGF370 . The Panasonic model number has a different final digit; that digit indicates the number of KX-TGFA30 handsets sold with the base.
The manual for the KX-TGF37x phones is available here: http://shop.panasonic.com/cordless-corded-telephones/cordless-telephones/KX-TGF37.html?supportpage=true#q=kx-tgf372&supportpage=true&PageName=true&start=1 . Scroll down or click on the Support link. The direct link to the manual is currently ftp://ftp.panasonic.com/telephone/om/kx-tgf372_en_om_.pdf .
I hope this helps.
Jun 19, 2017 | Lands Phones
User Manuel for panasonice cordless phone kztgea20
Do you mean the KX-TGEA20 cordless handset? I don't know of any KZ models in the Panasonic product line. If you do have the KX-TGEA20 handset, then Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tgea20_en_om.pdf . You can also find the manual on the product page, http://shop.panasonic.com/search?q=KX-TGEA20# . Select the S or B suffix depending on the country in which you use the phone.
If you need additional information on using the handset, check the manual for the base system. The KX-TGEA20 works with the KX-TGE210 and other models. The KX-TGE210B manual is available here: http://shop.panasonic.com/support-only/KX-TGE210B.html . The direct link is ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf .
I hope this helps.
Aug 02, 2016 | Panasonic Lands Phones
Additional handsets installation manual for panasonic kx-tga401
The KX-TGA401 handset can be located in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTGA401-INSTALL.PDF
May 26, 2014 | Panasonic Lands Phones
I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
Dec 05, 2013 | Panasonic KX-TG5583 Trio Cordless Phone
CHANGE GREETING ON MODEL KXTGA401
The KX-TGA401 is the handset. The greeting is controlled by the answering machine. What model answering machine do you have on your phone line?
Oct 03, 2013 | Panasonic KXTGA401B KX-TGA401B KX TGA401B...
My Sony cordless handset doesn't work and displays "S/C Invalid".
  1. Place the handset in the base.
  2. Unplug the AC power adapter from the telephone base.
  3. Disconnect all the telephone lines from the telephone base.
  4. Allow the telephone base to remain without power for 1 minute.
  5. Connect all the telephone lines to the telephone base.
  6. Plug the AC power adapter back into the telephone base.
Aug 31, 2010 | Sony SPP A973 Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
I have a 3 set of the above system KX-TG1033S. No dial tone
Try power cycle , or Reset base ,from handset menu . Check it out if there is reset menu in menu/setting /reset ...simular like that .
Feb 21, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG9341 (purchased 9/10/08)
I believe the problem is not the handset phone but the telephone line because the phones were working for a brief period again last night. As I said, ATT is supposed to send a repair man out today to check the lines. If the repair man says the problem is not the telephone line, I may contact you again. Thanks/
Nov 03, 2008 | Panasonic KX-TG1033S Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
