Question about Ovens
The oven on kitchenaid kesa907 won't turn off. No error codes, the 'off' button just doesn't work.
Cooking as usual in my oven, no problems, when I went to turn it off, the off button wouldn't activate. The oven continues to cook at the temperature I set it at. There are no error codes. I eventually had to shut the breaker off, wait a few seconds and then turn it back on. This is the only way to turn the oven off.
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
Posted on May 30, 2008
barkencoa
  • 3463 Answers
SOURCE: frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Posted on Dec 14, 2008
localwonder
  • 6784 Answers
SOURCE: when cooking will get an occasional f2 or f5 error code
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
Please rate and god bless:)
Posted on Apr 14, 2009
  • 30 Answers
SOURCE: fridgiaire oven inconsistent cooking temperature
needs a new temperature sensor
Posted on May 03, 2009
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Error message F6E6.What does this mean?
Although fault code "F6E6" most often indicates a communication failure between the User Interface and Appliance Manager board (Service Pointer W10538518), it could also indicate an incorrect electrical connection at the customer's home junction box. Sounds like you have some wires crossed!
Oct 18, 2014 | KitchenAid Architect ® II KEBS208S...
Just got error code "fe02"
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Sep 18, 2011 | KitchenAid Ovens
Lower oven will not common. The button to ignite the oven doesn't light up to start .
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 24, 2011 | KitchenAid Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
I was cooking in my Kitchenaid oven and the door locked. It will not unlock
We had the same thing happen
Turn the oven breaker off, then let the oven cool completely. Turn breaker on, there will be an error code appear, push and hold the "bake" button for at least one minute until an error message appears, then press the off button.
This reset the latch on our oven
Nov 02, 2009 | KitchenAid Ovens
When cooking will get an occasional f2 or f5 error code
Apr 05, 2009 | GE 24" Built-In Single Gas Wall Oven
Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
May 02, 2007 | KitchenAid KEMC378 Electric Double Oven
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
