Question about Scosche Industries Car Audio & Video
Scosche SCDBTA60A when hooked up to the wiring in my truck will not power on the head come on when first plugged in and then shuts off
Believe me that is only the start of your problems, the unit is one of the most disappointing things I have ever bought, it doesn't work using a memory stick either using the buttons or the app it needs a complete rewrite of both firmware and software and Scosche tell me they are not rewriting either so tough luck!! Check other forums for other opinions but whatever you do don't buy it.
Posted on Jul 31, 2014
  • William bogen Jan 15, 2015
    Anyome who has the issue with the radio just blinking on and shutting off, it meams its not getting a constant 12v ppwer, so you need to tie a wire to the yellow powered wire and tie it either to the bayyery or tie it into a constant powered fuse
Brand new system not working
check your fuses.
Could be just a defective product...
but really check those fuses
Apr 23, 2017 | SCOSCHE Car Audio & Video
Hey i have a scosche in-line fuse block i purchased. I haven't had any problems until recently. My fuse fried. So i bought more and went to replace it and every fuse i try instantly fries. i cant seem
Most likely the amplifier you have hooked up to that fuse position is defective and causing the fuse to blow. Or you have a short in the powerline somewhere. Disconnect the power wire from the amplifier, tape up the end so it won't short out to anything. Replace the fuse, if it doesn't blow then you will need to get the amp checked, if it does blow, then you have a short somewhere along your power wire.
Jan 30, 2014 | Scosche Industries Car Audio & Video
I want to connct a cd player in car1995 honda how to connect wires like plus and minus wires
If you still have the original stock radio plugs it's best to buy a wiring harness that will connect to the factory plugs. Then the wires are all labled to hook up any cd or radio.It's called a stereo connector made by scosche check it out.
Sep 11, 2013 | Cars & Trucks
I recently wired a eonon e1091 into a 2007 silverado classic. i used a scosche wiring harness that allows me to keep my chimes. everything works fine but when i turn the truck off, theres still power...
It's called delayed acc. power. It should shut off as soon as you open the door. Unless the red stereo wire is hooked up to constant power. You may need to check with a test light.
Oct 31, 2010 | Car Audio & Video
How to install Scosche - 2-Channel Adjustable Line-Out Converter
If it is an active converter and not passive, you should have three power wires, black goes to ground, yellow to battery, and red to the remote/amp (blue) wire off the deck. Then there should be four input wires. These connect to your speakers, white-white/black to left, grey-grey/black to right. Black line indicates ground, or (-). Then simply hook up the RCA jacks to your amp! Caution: the Scosche only accepts 80w of power, 40 per channel. Otherwise you rick blowing the converter, possibly the amp (usually a mosfet), and then possibly the subs, though not likely.
Mar 05, 2010 | 1999 Ford Explorer
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
Im puttin a new head unit with a different wire harness, i know what all the wires are on that wire harness, but with the 92 accord stereo wire harness i need to know which wires are speaker, remote, power...
You can buy a cheap harness from the local parts store for your Honda made specifically to put in aftermarket head units. Since you know the pin outs on your head unit, you can wire it up quickly uning this harness and it will plug directly into the factory Honda harness. Go to Scosche dot com part lookup for your number - I think the wiring schematic is on the outside of the package, too.
Apr 14, 2009 | 1992 Honda Accord
Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
Dec 28, 2008 | Scosche Industries Scosche Slc4 Speaker...
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
Car Audio & Video Logo
134 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
