Question about Heartland Fragrance Love Notes Warming Massage Oil Set of 3
Oil to thick TO SPEAD - Heartland Fragrance Love Notes Warming Massage Oil Set of 3
I have a Ford fiesta I put thick oil in now it won't start
change the oil with the proper weight, then get back to us
Apr 15, 2015 | Ford Fiesta Cars & Trucks
How to check my internet speed?((not from control panel)
Try www.speakeasy.net/speadtest/ works wonders for me. My internet proveder uses this. Measures your download spead and upload spead.
Feb 19, 2013 | Computers & Internet
Fluid leaking around the serpintine belt and this is helping it spead to under hood surface....more noise while running
If the fluid is oil it probably is the power steering pump. If it is coolant it is the water pump.
Jan 24, 2011 | 2007 Buick LaCrosse CXL Sedan
Low oil presure
change your oil and filter dont run real thick oil dont know where you live buts its cold outside makes oil get thick,i dont know if you change your oil like your supposed to, the oil screen could be stoped up if problem persist take it to a mechanic you can throw a rod
Jan 23, 2011 | 1999 Mitsubishi Montero Sport
Fan spead does not work after 2nd spead
Please check your selector switch and resistor box for malfunction
Jan 23, 2011 | Chevrolet Tahoe Cars & Trucks
I have a 2006 sportage kia, I have had the timing belt changed, a tune up done, the transmission fluid flushed, my car has approximately 82, 000 miles on it. I service it ever 3, 000 miles. However, when i...
could be a lead or plug breaking down which are the most obvious when under load ,but please explain why the transmission oil changed ?? i was always taught that auto boxes are for old women and the oil in them never needs changing .I have never seen this on any workshop manuals for the need to change the gearbox oil on a auto.
Sep 06, 2010 | Kia Sportage Cars & Trucks
Thick oil, blue smoke from exhaust
sound like you have blown head gaskets and water getting in the oil
Mar 08, 2010 | 1998 Saab 900
Something isn't catching
Your clutch is slipping, doing this might ruin the flywheel. I cannot tell if this is wear or more likely an oil leak (slipping that much is normaly accompanied by lots of smell and smoke if it is a slip, not with oil leak though)
Oct 27, 2009 | 2004 Mazda 6
My oil is a thick paste
could be. the oils should not be like a thick paste. what is the color?
if it is black, then it is ok but if it is grayish in color, then it is already mixed with water.
that is a major problem. water and oil should not mix.
could be a broken head gasket.
tnx 4 using fixya,
drcool
Oct 24, 2008 | 1986 Mazda 323
Heartland Fragrance Love Notes Warming Massage Oil Set of 3 Logo
79 people viewed this question
Top Heartland Fragrance Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Heartland Fragrance Health and Beauty Expert? Answer questions, earn points and help others
