Question about Precor Efx-5.23 Elliptical Machine Cross-trainer Fitness Exercise Equipment 823
No power after a power surge
We had a power surge and it zapped a few things in my home . My 5.23 shows no life signs is there a fuse or a breaker to replace?
  • Precor Master
  • 918 Answers
Here's a link that will take you to the page for a few 5.23 models. You'll want to narrow the search on the left column by serial number to get to the correct information on your exact model.
Repair Parts for Precor 5 23 Ellipticals Consumer SPORTSMITH net
Here's a link to a few fuses that are listed for the 5.23's: To determine which one is correct, you'll need have your serial number off the machine:
Posted on Nov 17, 2014
I have a Vizio XVT473SV with no video or audio, but the Vizio standby lights up.
I would say its most likely the power supply. Quite often after a power surge this can happen. Another option could be that the surge just blew the fuse on the power supply board and replacing that may be all you need. That said, usually you will get no signs of life at all if the fuse blows.
Jan 22, 2018 | Vizio Televison & Video
Plugged in not charging
It could be a few things. The most common is that the charger was zapped during a lightning storm or a power surge. This would require you to replace the charger. Another reason could be that your battery voltage level is too low some chargers will not come on if the voltage level is below 16v. This sometimes requires the batteries to be replaced. Get them load tested before you replace them by your local battery shop to determine if they need to be charged or replaced. The last thing that is not very common but happens is that the inline fuse has been blown. If this has happened, you will need a qualified service tech to determine the reason the fuse was blown. This should never be the problem unless ther is a serious problem with your wiring.
Dec 17, 2013 | Health & Beauty
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 27, 2012 | Belling Ovens
Had electrical prob. blew some breakers for kitchen circuit. After fix all other affected appliances/outlets etc. are fine but KitchenAid dw now does not work. No sign of life at all, no led's light on...
Hi and welcome to FixYa. I am Kelly.
With electronic controlled appliances today and in this case your dishwasher. The printed circuit board (PCB) transformers are very susceptible to power surges. The windings are just large enough for the normal operational voltages. Anything above or below that range causes the windings to fail rapidly. When they fail you do not get the 5V or 3.3 V for the LEDs ' and IC chips or the 12V for the controlling the relays for normal operation.
I don't see a model number listed for your dishwasher so I can not provide the replacement part information at this time.
Before I went into the parts changing mode I would first go back and reset every breaker in the house by:
1. Pushing each breaker with conviction to the OFF position. This completely resets the breaker.
2. As you turn each of the breaker ON push hard on the face of the breaker near the center of the main panel to ensure it remains connected / engaged to the main power buss bar.
Then go back and check the dishwasher for signs of life. If it works great! If not.... I will be watching for model number information if you need help with the dishwasher control parts information.
Just a side note... you may want to check your home owners insurance coverage (if your a home owner) to see if it covers repair of equipment other than the one that caused the original problem.
Thanks for using FixYa.
Kelly
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Heater is not coming on
That makes sense, you were pulling well over over 20 amps. It doesn't make sense but it appears the heater failed. I would assume the heater has an electronic control that got zapped by the surge generated by the vacuum cleaner when the breaker tripped. If it is not an expensive heater just get a replacement. Unless you are experienced in repairing these things it is much safer just to replace it.
Good Luck,
Gilshultz
Dec 01, 2009 | Holmes Products HOH2501 Oil Filled...
We are using this server for more than 3 years. yesterday, server switched off due to voltage surge. afterthat it is not turning on. even smps not switching on..
Sounds very likely that if the power supply isn't even showing signs of life then the surge has killed it, it'll need to be replaced. If your lucky then no other components have been damaged.
The supply in that unit (according to google) is an IBM 340W Power Supply - 24P6898. My searches have found a few refurbished units for about £40.
Nov 20, 2009 | IBM eserver xSeries 205 8480
Completely dead; no problem at the house circuit-breaker box
Check the fuse . They all have fuse's and thats all ways the first thing to happen. If you need help doing this at home I will help you, DFD
Apr 20, 2009 | Microwave Ovens
I recently changed my battery
did you change your battery ? there is a procedure for replacement of the cables. If you do it incorrectly odd things happen. It is probably a fuse or a relay out. if you have a owners manual find the ones for those things. but dont change them yet. When changing a battery. Install the Positive side (red) first. but make sure the clamp or fastener is clean. put some petroleum jelly on to keep out corrosion. then install the Negative ( black) otherwise you get a power surge when the computer and other memeory features regain. think of it as a 650 amps or the 15amp fuse in a breaker box in a home .. times 20 surging thru your home computer. Pretty much the same effect. ...household current is 110 volts at 15-30 amps and auto is 650-850 amps and 12volts.
Apr 04, 2009 | 1998 Mercedes-Benz C-Class
Doesn't power up
Same problem here, working one minute, lights out the next. No signs of life. Hoping there is a fuse or breaker somewhere.
May 12, 2008 | Gaggia Syncrony Compact Coffee...
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Precor Efx-5.23 Elliptical Machine Cross-trainer Fitness Exercise Equipment 823 Logo
192 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
