Question about Acer Computers & Internet
Acer motherboard a springvale-6A79AFK8C-00 will not hold date &time in bios battery ok
  • rwsayers Jun 14, 2009
    thanks for comment but jumper link is on pin 1&2 marked normal
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
Have you checked to make sure that the cmos jumper has not been left to the reset position?
You said the battery is good and the next step would be to make sure the jumper that clears the cmos is in the correct position and is set properly to prevent cmos from losing the settings.
DARK
Posted on Jun 14, 2009
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
Battery dead & BIOS reset. CD & DVD drives lost.
first you will need to replace the cmos on the system board(or have a qualified computer service tech. do it). then you will need to access the bios settings by Pressing F1 immediately after powering on the computer. once in the bios, you can set the correct date and time. Also, you will need to check the drive settings to verify that the hard drive and any CD/DVD drives are recognized. once done, then exit the BIOS being sure to chose "save and exit", then allow your PC to boot normally. this should fix your date and drive issues. if not then the motherboard may be defective.
Dec 29, 2013 | Computers & Internet
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
P4P800-VM BIOS was Upgrade but BIOS Date & Time can't save from BIOS
If your cmos battery is new and the date and time not change. Try the following.
1. Clean the cmos battery terminals.
2. Check your mother board if there is bulges capacitor.
3. Check the memory you have using if in the same voltage requirements.
Hope this will help to you.
Jun 15, 2012 | ASUS P4P800-VM Motherboard
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
Where is the battery that powers the Internet time/ date?
The motherboard BIOS battery keeps the motherboard setting and the date and time correct just like a watch battery. This BIOS battery is usually a 3 volt lithium battery, it is a coin size battery approx. 20mm in diameter most likely a CR2030 battery.
If you have a Internet time program that connects to the Internet, it will synchronize the computer's time with the Internet time.
Feb 13, 2011 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Every time i switch my acer aspire on it goes back in date and time to 2005 ..i have changed the battery on the motherboard to no affect..help!!!!!!
You just set up the time in BIOS setting. To get the BIOS just press delete during your laptop is on. Go to CMOS to change the time. Use arrow key to select after that you need to save just press F10 to save settings.
Mar 16, 2010 | Acer Aspire 1640Z Notebook
Hi. The clock on my Acer will not keep the correct time any more and it doesnt change dates on the calendar either. Do I need to change a battery in my motherboard?
If you change the BIOS date and time and when you boot up next time and the date and time has changed back or is incorrect, then the most likely fault is a flat BIOS battery. Replace the BIOS battery, it maybe a coin type lithium 3volt battery. this is the most common type used in motherboards is a CR2030 lithium battery.
Nov 03, 2009 | Acer Aspire 5630 Notebook
Acer springedale 6A79FK8C-00 motherboard will not hold date and time in bios
if it not hold u have to change cmos cell.
Open cpu cabinet u can find 1 cmos round cell on motherbord .
Change it.then u can save settings.
Jun 13, 2009 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
