Question about Ovens
Setting cooke Lewis clock on oven - Ovens
2 Suggested Answers
DIESELMUDDER
  • 2760 Answers
SOURCE: Cooke and Lewis multifunction single oven
if your referring to the light with the squiggle line above it ? this is the power on light (the squiggle line is the universal sign of power ) if your referring to the lights on the functions knob (left knob) there are tiny lights that come on behind these little pictures on there , the pictorgraph on the left side is for the broiler I do believe , this also gives one an option to use the convection fan to spread the heat about inside and evac the food cooking oils from inside the case , a light beep is a confirmation of a feature being issued to be used three long beeps happen when desired oven temp is reached , the knob only activates the feature after knob is set for more than 5 seconds there , this is a little fiddly bit as most folks don't think its workin and keep twisting it about never allowing the timer to complete its cycle
Posted on Sep 29, 2015
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Stoves 900 ef heritage doubel oven. I cannot seem to get the oven to work as my daughter has fiddled with the clock which has to twisting knobs - one saying cook time and the other saying start time. I...
For the 720ef , this is what you need to do. Hopefully this will translate to your 900.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
To reset the cook time, use the plus and minus buttons to set it to zero.
To cancel the automatic setting and return the oven to manual operation, press the COOK TIME and READY TIME buttons simultaneously.
I hope this helps.
Jul 28, 2011 | Stoves 720EF Electric Double Oven
Moved to house with a Simpson Neptune oven (analogue clock)
Try this. For the 720ef , this is what you need to do.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Jun 17, 2010 | Stoves 720EF Electric Double Oven
Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Apr 06, 2010 | Ovens
I have a older Frigidaire oven model #RG74BC. I have messed with the timer knobs and the oven will not come on. Does anyone know what setting the knobs need to be on to fix this problem
You have probably inadvertantly put the oven into Automatic cook mode, where the oven will not come on until a preset time.
Try pressing/turning the clock/timer buttons and resetting the clock and this should put the oven back into Manual cook mode and you should be ok.
Jan 10, 2010 | Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
77 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
