Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
I have a Saeco Incanto Rondo with a grinder related problem
Hello. Im a coffee machine technician who works on commercial machines. A friend of mine has given me his machine so as to rectify a problem to do with internal grinder. Having not opened one of these units before I thought I'll have a look. The idiot put ground coffee in the chute causing the plastic blades to seize upon inspection. I disassembled the grinding unit leaving the pick up wires intact. After a couple of minutes in hot water I was finally able to pull the top blades apart from the bottom. I cleaned the complete unit along with all necessary ducts.
My problem now is that the machine starts grinding when button is depressed however it only grinds for 1-2 seconds before the right red warning lamp comes on. I assume it must be related to the grinder as my friend says it was working fine beforehand. The little bit of coffee ground actually goes into the chamber where its supposed too.
If you have a programming solution or any other thought on this machine it would be greatly appreciated.
Thank you.
  • justforthegi Jun 18, 2009
    Thanks for the reply. The grinder actually turns upon pressing the brew button but for only a few revolutions. Thus its plugged into the board. The grind looks fairly coarse. I'm almost certain that it may be the optical pickup under the grinder gear that may be faulty.
    Problem Solver:
  • 5 Answers
First step.If the grind is to coarse the burrs will spin to fast sensing no beans.
Solution: The grind needs to be finer. Caution you can over adjust causing the clay burrs to shatter.
Bruce
Gold Roast Coffee
www.goldroast.ca
Posted on Jun 25, 2009
  • 20 Answers
If the grinder spin for a fraction of a seconds and stops, it sounds like the sensor wire is not connected properly, OR the grinder is too tight, it was sensing grinder is jammed. Try grinding without beans, it will spin for a few seconds and stopped and the redlight will come on meaning coffee beans empty.
Posted on Aug 02, 2009
    President:
  • 1,618 Answers
Have you tried going to a coarser setting on the grind, adjust about 4 numbers to start.
Posted on Jun 18, 2009
  • Ernest R
    Ernest R Jun 18, 2009
    If that does not work, did you disconnect the wires of the grinder from the board?
4 Suggested Answers
mirran
  • 515 Answers
SOURCE: SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Posted on Jul 22, 2008
  • 1089 Answers
SOURCE: saeco incanto rondo boiler reset
There are thermostats (2) on the side of the boiler colsest to the side of the machine. There is a reset button on each between the wires terminals. Push both.
Posted on Dec 12, 2009
espressonist
  • 1711 Answers
SOURCE: ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Posted on Feb 25, 2010
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco machine grinder
Due to the use the grinding burrs are slightly move and wire out. So I advice you to move only one max two step to more fine coffee grinding from the one you have and try the coffee.
The test you have to do is that for about 30 cc of coffee the time that the coffee will run should be about 20 to 22 seconds. If the coffee more faster you need more fine grinding. If the coffee run more slower than 28 sec you need more gross coffee grinding.
Good luck
Mar 23, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Ave an SAECO INCANTO RONDA with milling problems.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco incanto rondo boiler reset
Dec 11, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Jun 02, 2009 | Saeco Incanto Rondo
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Red Light on left is blinking on our Incanto Rondo
Press and hold the hot water botton for 5 sec. and the light will go off; It will light after 1year again, to change the water filter;
BR,
Dec 22, 2008 | Saeco Incanto Rondo Fully Automatic Coffee...
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
785 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
