Question about Panasonic Viera TC-37LZ85 LCD TV
External speakers how do I connect external speakers.
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
Connecting external speakers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Feb 18, 2012 | Computers & Internet
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
How to connect external speakers to this tv. Only output jacks exist for audio.
Most of the TV's do not have a speaker output and so you will need to open the set and take the speaker connect to be meshed along with a impedance matching.
You can connect with a switch wherein the TV speakers can be switched OFF and the external speaker connected . If not the external speaker if connected in parallel must not bring down the impedance to a lower level not supported by the output IC.
The other option is to use the output AV to connect to an amplifier and speaker. ( Your Audio system)
Feb 08, 2011 | Televison & Video
Can i connect external speakers
gjrob,
You can connect external speakers with you model only if you have an external source of sound such as a receiver. This model does not have speaker outputs to directly connect speakers but it does have audio out connections that can send the sound from the tv to another source like the receiver.
On the back of your tv on the left there are connections listed under "Out". There is where you will find the audio out connections (red and White).
-Chris
Mar 02, 2010 | Toshiba 27AF41 27" TV
My mother board has power but no ms dos bleeps when i boot .... it gives power to every device like hard disk and floppy and so on but no ms dos bleep ?
check whether motherboard has inbuilt speaker or speaker connected externally.
Externally means check the proper connection is given for the speaker.
If speaker is connected externally in proper manner still no beep means problem is in the external spaeker
Mar 02, 2010 | Intel Motherboard
How can I connect external speakers to my Vizio VA26LHDTV10T?
Used the earphone plug with amplified speakers.
Dec 24, 2009 | Televison & Video
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Panasonic Viera TC-37LZ85 LCD TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
