Question about NetGear WGR614 Wireless Router
Link modem to router but keep getting warning that network cable is disconnected.
  • 428 Answers
Hope the modem is and ADSL or any other Internet modem.
Plug the modem ethernet cable into the WAN port on the router. Go into the router and configure PPoE with username and password. Set up a LAN connection to the router on your computer. Make sure that your firewall is not blocking the router internet connection.
If the port is not lighting up, it may be a dead port.
You have to check the ip addresses. I thinks that might be the problem. You can check using Start_>RUN->cmd and hit enter. The type ipconfig /all. Check the ip address settings. If they are in different subnets, you have to configure it. I think your router assigns dhcp addresses. Modem is assigned an ip address from the Internet Service Provider. What you have to do is get a browser and go type the router address. Then authenticate yourself and change wan settings. Configure everything there to use the modem as a part of the router. (ISP information should be provided there).
Then make sure that your router doesn't assign a dhcp addres to the modem.
Try to configure and check. Hope this would help you. :) tc
Posted on Jun 14, 2009
I changed my cable modem and now my router wont work
With an always-on, high-speed Internet connection like DSL (Digital Subscriber Line), a router is a prudent addition to your local network.
It filters out unauthorized access to your network, which prevents an intruder from accessing computers that are connected to that network.
However, getting your computers, routers and modems on the same page may not work right "out of the box."
There are a few things you must be aware of, especially if this is a wireless network.
Unplug your DSL modem and D-Link router.
In order for the network to properly recognize its devices, these devices must be attached in a specific order.
Plug in your DSL modem's power cord.
There is usually no power button on a modem.
Simply plugging in its electrical cable will turn it on.
Give your DSL modem a couple minutes to re-establish its connection to AT&T's network before taking any further action.
Plug in your D-Link router's power cord.
Like the DSL modem, this router will probably not have a power switch; simply plug in the power cable, and it turns on.
Let the D-Link router sit for a couple minutes while it establishes its connection to the DSL modem and AT&T's network.
Physically attach your computer to the router with an Ethernet cable.
Even if the router and modem are wireless, a physical connection must be established to properly configure the router.
If this is not a wireless network, then your setup procedure is essentially complete.
To access a D-Link router on your network, open an Internet browser and navigate to the 192.168.0.1 address.
This will bring you to your D-Link router's interface.
The default User Name is "admin" (without the quotes), and there is no password.
Enter the User Name and click the "Log In" button. This will bring you to the Setup window.
Refer to your D-Link router's documentation for changing the default password (highly recommended) and forwarding ports.
If this is a wireless network, you have a couple further steps.
First, change your network's SSID (Service Set Identifier) title, so that you can recognize it when other wireless networks are nearby.
Also, choose your wireless encryption and passphrase. WPA2 (Wi-Fi Protected Access 2) is a solid option.
Specific instructions depend on your model of D-Link router; so refer to your documentation (which can usually be found at the manufacturer's website if you do not have it on hand).
Disconnect the Ethernet cable from your computer.
Your new wireless network should be visible with your computer's wireless adapter.
Windows and OS X will notify you of networks in range when your adapter is active.
Connect to the one with your SSID, and enter the passphrase.
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Aug 07, 2013 | D-Link DIR-655 Wireless Router
Tip
Internet keeps disconnecting - Internet disconnect
Having intermittent internet disconnects? There could be a couple of causes for this issue. Your internet could be degraded when it gets to your house causing disconnects. You will have to contact your Internet Service Provider in order to have them resolve this issue. Normally, they will replace splitters and may even replace lines outside of your house. You could also be having problems with the modem directly. The may replace this. If you have a modem that you bought that was not provided by your ISP, you can try to update the firmware on the modem.
If using a modem
I recommend you unplug the router, plug the computer directly in the modem and see if you still have the problem. If you still have the problem then you know it is just the modem. If the problem resolves itself then you know the most likely culprit is the router.
I would also recommend that you update your router firmware as well. Do a google search for the brand name of the router and go to the companies website, look in the support/downloads section for updated software.
--If possible, try a different Ethernet port on your router. You may have a bad port.
--Take out and reinsert all Ethernet cables on your network. Loose cables can cause disconnects.
--If possible, replace the Ethernet cables. Bad cables can cause this.
Lastly, you could be having an issue with the Network card(NIC) on your computer. Network cards are either built into the modem or external(a card you insert into the motherboard). Using the process of elimination and the steps above, you can hopefully narrow down the problem to one specific component of your network.
Regards,
G33k
Keywords
Internet disconnecting, internet keeps disconnecting, internet disconnects, internet not staying on, internet shuts off, internet keeps shutting off
on Jun 14, 2011 | Computers & Internet
How do i connect my tp link router to my dsl modem
* 1 Unplug your DSL modem and D-Link router. In order for the network to properly recognize its devices, these devices must be attached in a specific order.
* 2 Plug in your DSL modem's power cord. There is usually no power button on a modem. Simply plugging in its electrical cable will turn it on. Give your DSL modem a couple minutes to re-establish its connection to AT&T's network before taking any further action.
* 3 Plug in your D-Link router's power cord. Like the DSL modem, this router will probably not have a power switch; simply plug in the power cable, and it turns on. Let the D-Link router sit for a couple minutes while it establishes its connection to the DSL modem and AT&T's network.
* 4 Physically attach your computer to the router with an Ethernet cable. Even if the router and modem are wireless, a physical connection must be established to properly configure the router. If this is not a wireless network, then your setup procedure is essentially complete.
To access a D-Link router on your network, open an Internet browser and navigate to the 192.168.0.1 address. This will bring you to your D-Link router's interface. The default User Name is "admin" (without the quotes), and there is no password. Enter the User Name and click the "Log In" button. This will bring you to the Setup window. Refer to your D-Link router's documentation for changing the default password (highly recommended) and forwarding ports.
If this is a wireless network, you have a couple further steps. First, change your network's SSID (Service Set Identifier) title, so that you can recognize it when other wireless networks are nearby. Also, choose your wireless encryption and passphrase. WPA2 (Wi-Fi Protected Access 2) is a solid option. Specific instructions depend on your model of D-Link router; so refer to your documentation (which can usually be found at the manufacturer's website if you do not have it on hand).
* 5 Disconnect the Ethernet cable from your computer. Your new wireless network should be visible with your computer's wireless adapter. Windows and OS X will notify you of networks in range when your adapter is active. Connect to the one with your SSID, and enter the passphrase.
Sep 06, 2011 | Computers & Internet
My internet keeps disconnecting, never had this before, the internet disconnects, i restart the router manually and internet is back up for about 5-10 minutes and it disconnects again. Everytime i look...
There could be a couple of causes for this issue. Your internet could be degraded when it gets to your house causing disconnects. You will have to contact your Internet Service Provider in order to have them resolve this issue. Normally, they will replace splitters and may even replace lines outside of your house. You could also be having problems with the modem directly. The may replace this. You could also try to upgrade the software on it. Click here for the update page for Arris.
Typically, I recommend you unplug the router, plug the computer directly in the modem and see if you still have the problem. If you still have the problem then you know it is just the modem. If the problem resolves itself then you know the most likely culprit is the router.
Let me know if you have any questions.
Regards,
G33k
May 16, 2011 | Arris Touchstone 450a (CM450) Modem
I need to connect a D-Link router to my cable modem so that I can use my laptop anywhere in my home
Cable-modem <-- Ethernet cable --> WAN (or "Internet") port on the router
LAN port on router <-- Ethernet cable --> network-port on your laptop
Then, access the "built-in" web-server on the router,
and run the "Wireless Networking Setup" wizard:
* to set an SSID ("network-name")
* an encryption-level (Hint: choose 'wpa')
* a password for your wireless network
Then, disconnect the Ethernet cable from your computer,
and then "wireless available wireless networks".
Select your newly-created network, and connect to it.
Nov 14, 2010 | Computers & Internet
It worked fine last nite;came home today and it wont pull up the eweb or start or anything I click on? It said at one point I was not connected to any network;now it says am connected to Netgear network. I...
There are lots of possibilities here. The first thing is IF you are connected through a wireless network, Disconnect from the network. If you are networked directly into the Comcast modem, disconnect from the cable modem. If you disconnect from the network entirely and things seem to return to normal, then it is possible that you have a cable modem problem, a wireless router problem or someone has hacked into your network. The latter is most likely if you are running a wireless router and it is unsecured as this allows others to use your wireless network without your permission. If you disconnect from the network and things seem to improve only slightly, try running a virus scan while disconnected from the network and see what pops up. If anything has been downloaded to your computer a virus scan should find it. I would also recommend going in and making sure file sharing is turned off. If things seem okay after a virus scan, then try hooking back up to the network. If everything seems okay at that point, then most likely the cable modem or router are okay. If you still have a problem after reconnecting to the network try resetting the cable modem and the router. If you continue to have problems, I would call Comcast at that point and have them help you troubleshoot the cable modem to see if there is a problem with the modem.
Jan 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Wireless network gets disconnected
i believe it supposed to be
modem--> vonage -->router
-->phone
Jul 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I've connected the cat 5 wire from my cable modem to the linksys cable router with 8 ports but it does not give access to the internet on the other computers that are networked. If I let it find an...
hey, you need to create bridge between your cable modem and router and you need to give one static IP in the router. kindly note you need to keep cable modem and router in the same class eg-( cable modem ip is 192.168.1.2 then router should be the same range.) and provide gateway of your ISP in the router.
Jun 09, 2009 | Arris SURFboard SB5120 Modem
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
NetGear WGR614 Wireless Router Logo
48 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
