Question about Ingersoll Rand 311a Air Dual Action Quiet Sander Ir311a
Sander won't shut off - Ingersoll Rand 311a Air Dual Action Quiet Sander Ir311a
  • 26 Answers
Most likely the throttle valve is stuck open. On sanders usually sanding debris has coated the throttle valve pin, causing it to stick. Other times the throttle valve seal has worn and needs replacement.
Posted on Aug 13, 2014
The edger runs when switched on but then shuts off when I start to sand with it. The brushes and switch have been changed on it.
check the belt and the pinion..had same problem...replaced the belt and the pinion drive, works fine
Dec 15, 2013 | Bona Edge XL Flooring Edger Sander
Clarke sander
Once we plugged it into an outlet with a trip switch it worked.
Jul 28, 2013 | Tools & Hardware - Others
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
No powerto sander. Cord is good,switch is good and brushes are long
It sounds to me that you have used the sander a lot and the vibration has broken a wire or it's about to break on the field windings. The brushes you need to look at to see if worn. But I kind of think wire problem. I had this happen on mine and opened it up to find this is what happened. The sander would be turned on and would not operate until I turn upside down and it would work. This is great if you are sanding upside down but this is just a sign that you are on borrowed time as this will eventually not turn on at all. I was able to fix mine with new wire crimp connection and solder with heat shrink material. If not you can order new field winding if this is what is wrong. Cleaning up the sander won't hurt either. You might want to see what a new sander will cost vs. part. Good Luck!
Aug 23, 2012 | Dewalt Sander,random Orbital - DEWALT
Skill 7292 hand sander won't turn on
a lot of times sawdust gets into the switch contacts and won't allow the tool to operate. I would try turning the switch on/off several times and see if it temporarily helps. Also check the cord. Let me know if you need more assistance.
Feb 23, 2012 | Tools & Hardware - Others
We rented a sander to sand our pool deck. it worked at first but now won't budge. it turns on but can't even push it forward.
Hello Radlad84,
There are few things you can look at.First see inside the sander if it full of dust and then clean it .
Second look for the brushes inside .they should have a proper length.
Good luck.
Appie from the Netherlands
Jun 04, 2011 | Tools & Hardware - Others
Model no 333 wont start unless i turn it on its side?
Aug 15, 2010 | Porter Cable 332K Quicksand Random Orbit...
Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
The floor sander will work for a few seconds then cuts out. this is the second sander where this has occured, we have tried running extension cords to other outlets/ laundry hookups also
its not getting enough amperage. poor wiring or thin extension cords will cause this. make sure you use a thick cord that is rated high enough to supply the sander.
Aug 08, 2009 | Tools & Hardware - Others
On a cp864 the throttle is wide open ,, wont shut off
http://www.airtools.com/catalog/ItemListView.aspx?id=148 try this
Feb 27, 2009 | Chicago Pneumatic CP864 Dual Action Air...
Ingersoll Rand 311a Air Dual Action Quiet Sander Ir311a Logo
651 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
