Question about Relisys RLT1720 17" LCD Monitor
Problem with monitor going black
Dell tft model e173fpb when u turn it on it then turns off the light is showing on but it does not display a pitcure
any ideas
  • Anonymous Dec 15, 2007
    when I turn my monitor on it stays on but goes black after about 2 seconds.. can you help me find out what I can do to fix it???
  • afika Feb 26, 2008
    My LCD monitor has been off for a long time about 2 months and now when I try to switch it on the LED goes green and back to orange, there is no problem with the PC as I have checked with the other monitor. Please help
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPUproblem with monitor going black - 1.gif and monitor. After it goes black, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Mar 13, 2008
When I turn on the power my E173FPb lights up for only one or two seconds and then goes black and the green on-light remains illuminated. try on other computers same thing, am i wasting my time fixing was...
Hi there! You can test first if the monitor is working. Disconnect it from the computer then turn it on after that it should show you colors on the screen this means its working if not then its no use trying it on a different computer.
Hope this helps!
Sep 06, 2011 | Dell E173FPb 17" TFT LCD Monitor
LIGHT VIEW 17" TFT MONITOR LM17SB OUT OF RANGE WHEN USING WINDOWS 7 WORKS FINE WITH VISTA
Set your resolution from "Display" which you can find in control panel. And fix the resolution at 1280 by 768.
Regards
Ashly
Feb 02, 2010 | Dell E173FPb 17" TFT LCD Monitor
Monitor went to black. checked and changed all
Check our web site at: www.ccl-la.com/badcaps.htm We have a free repair guide for that model Dell monitor.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 03, 2009 | Dell E173FPb 17" TFT LCD Monitor
Black box in middle of screen
Push your memu button and it should disappear.If that doesn't work, contact Dell.com and they will talk you through it.
Sep 14, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell monitor 173FPb
The flashing is an error code. Call Dell Tech support & they can tell you the exact problem. Hope this helps.
Dec 28, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb monitor has gone black with green light (on/off switch) flashing.
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Monitor trouble shooting
what would i do for my monitor that went blank
Apr 07, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Flat Screen trouble
you need to replace switching transistor 2SC5707 in the Power Inverter Board.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
Oct 03, 2006 | Dell E173FPb 17" TFT LCD Monitor
Relisys RLT1720 17" LCD Monitor Logo
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
