Question about Ingersoll Rand 311a Air Dual Action Quiet Sander 6" Pad
Ingersoll rand 311a doesn't shut of completley
SOURCE: ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
  • 174 Answers
SOURCE: Automatic on/off switch: Ingersoll-rand contractor series
this would bee called a pressure switch
Posted on May 31, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
  • 214 Answers
SOURCE: ingersoll rand ep10-esp problem with
Did you replace the separator filter located inside the separator. If not replace it. If it was replaced check the scavenge line and orifice. make sure they both are open. Also make sure the orifice is orientated correctly. If you look at the orifice closely it should have an arrow etched into the side. the arrow points toward the air end.If this is an ESP unit they gave alot of problems and expensive to repair. Oil coming out of the air filter is often caused by the minimum pressure check valve leaking by or just not closing at all. I would suggest dis-assembly of the MPCV to see if it is leaking or possibly stuck open. If the above does'nt take care of the problem and this is an ESP please forward the model and serial # and will try to see what else I can find.
Posted on May 11, 2011
Sander won't shut off
Most likely the throttle valve is stuck open. On sanders usually sanding debris has coated the throttle valve pin, causing it to stick. Other times the throttle valve seal has worn and needs replacement.
Mar 17, 2014 | Ingersoll Rand 311a Air Dual Action Quiet...
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
Chuck on ingersoll rand air drill doesn't turn even without air pressure
pull it apart and check bearings and fibre blades check that they are not cracked or jammed from dried lubricant.
Oct 02, 2011 | Ingersoll Rand Ingersoll-Rand 1/2" Heavy...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
How do i use this thing
Yes it should screw on and the sanding pads should either be sticky or velcro
Oct 02, 2008 | Ingersoll Rand Ingersollrand Dual Action...
Ingersoll Rand 311a Air Dual Action Quiet Sander 6" Pad Logo
425 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
