Question about Seiko Label Office Equipment & Supplies
Invalid PRINT_INFO structure - Label Seiko Office Equipment & Supplies
I cannot print with my Mac Book Pro. Correct printer is added already.
The mapping info is lost after the router and wifi change . Reconfigure the laptop settings for this . My previous answer would be invalid because you dis not mention WiFi
Jun 24, 2015 | Office Equipment & Supplies
My MAC G5 disk utility repair cannot repair selected items
use disk utilty from system disk by restarting computer holding down c key then go into disk utility and try it.
Jan 21, 2014 | Apple Power Mac G5 Desktop
ERROR SYNTAX
Error Syntax mean that the structure of the entry is incorrect. For example, x+-y (x plus minus y) is invalid; whereas, x+ (-y) (x plus negative y) is correct.
Apr 01, 2013 | Texas Instruments TI-89 Calculator
" 49.FF04 Error Turn off
Critical firmware error. Can be caused by invalid print commands, corrupt data, invalid operations or even electrical noise in the cable.
Turn off the printer, then turn it on.
Press Stop to clear the print job from memory.
Turn off and back on.
Print a document from a different software program.
If that document prints, go back to the first program that failed and print a different file.
If the error comes back, that file is corrupt.
If the message persists with different programs and print jobs have the formatter replaced.
Apr 16, 2011 | HP LaserJet P4014n Printer
Printer character very small , how to character normal
A character set is presented with which unscaled 2D molecular structural diagrams can be constructed. A minimal subset has been implemented in ROM on CBM microcomputers, whilst the complete set has been defined as a character font on an ICL PERQ computer. Structural diagrams have also been output on dot-matrix and daisy-wheel printers using appropriate software to print the special characters. The character set provides a simple means of displaying molecular structures on inexpensive microcomputers, on printers and on hardware offering user-definable character fonts.
Oct 25, 2010 | Posiflex PP7000 Printer
I900d waste ink tank getting full
· 1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press
RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
or try this
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps you.
Sep 15, 2009 | Office Equipment & Supplies
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
May 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
DISPLAYS ERROR MESSAGE: W2 INVALID PERS. WHAT DOES THIS MEAN AND HOW DO I GET IT TO PRINT?
FROM THE SERVICE MANUAL
W2 INVALID PERS:
The job was not printed because the requested personality,
such as PostScript, was not installed. Install the language in
which the files are sent, together with enough memory to
support that language.
I SUGGEST CHECK IF YOU GOT THE POSTSCRIPT INSTALLED
May 04, 2009 | HP LaserJet 4 plus Printer
51 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
