Question about Cell Phones
How to reset starmobile HIT - Cell Phones
HOW DO YOU RESET THE LAMP USE TIME ON THE JVC HD 56 G787 REAR PROJECTION
u need the real remote rm-18g hit menu till u get to lamp reset hit enter a screen will come up that says press ok to reset lamp timmer hit ok button than another screen will come up that says the lamp timmer was reset successfully
Sep 08, 2013 | JVC HD-52Z575 52" Rear Projection...
Barring password for starmobile mercury b203
how to format my B203 starmobile
Jan 10, 2013 | Cell Phones
My 2007 Dodge ram 1500 with hemi has 2 codes po524 and po406 are they related
In both cases, there is a software update available for this condition. It involves having the dealer connector their StarScan tool to your truck and reprogramming the PCM.
DTC P0406 - EGR Sensor "A" circuit "High"
There is updated software available for your PCM that will correct this code if your vehicle was built prior to mid February 07. If it was built after that, then the EGR valve will need replacing (this is not unusual). Keep in mind that could be time for a new valve, but you dont will need to change the tube, but new gaskets are a good idea.
DTC P0524 - Oil Pressure Too Low Oil pressure sending unit (sensor) voltage input above the maximum acceptaple voltage.
If the software is up to date, then have the oil pressure sensing unit must be replaced.
Additionally, check this TSB SUPERSEDES TECHNICAL SERVICE BULLETIN 18-044-07, DATED OCTOBER 12, 2007, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL
REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION OF YEARS, MODELS AND CLEAN DATES.
THE StarSCAN FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM THE INTERNET.
StarSCAN SOFTWARE LEVEL MUST BE AT RELEASE 8.04 OR HIGHER FOR THIS BULLETIN.
StarMOBILE STANDALONE MODE OR StarMOBILE DESKTOP CLIENT MAY ALSO BE USED TO PERFORM THIS PROCEDURE.
SUBJECT:
Flash: MIL Illumination Due To Diagnostic Trouble Code P0524 - Engine Oil Pressure Too Low
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
**2007** - 2008 (DR/DH/DC/D1) Ram Truck (1500/2500/3500)
**2007** - 2008 (HB / HG) Durango / Aspen
**2007** - 2008 (LX) 300 / Magnum / Charger
**2007 (LE) 300C/300 Touring (International Markets)**
**2007 (L2) 300 (China)**
**2007** - 2008 (WK) Grand Cherokee
**2007 - 2008 (WH) Grand Cherokee (International Markets)**
**2007** - 2008 (XK) Commander
**2007 - 2008 (XH) Commander (International Markets)**
NUMBER: 18-003-08
GROUP: Vehicle Performance
DATE: January 19, 2008
NOTE: This bulletin applies to the above listed vehicles equipped with a 5.7L engine with MDS (sales code EZB) built before the following dates:
(HB/HG) built before August 15, 2007 (MDH 0814XX)
(LX) built before September 14, 2007 (MDH 0914XX)
(DR) built before August 16, 2007 (MDH 0816XX)
**(WK/WH/XK/XH) built before January 8, 2008 (MDH 0108XX)**
SYMPTOM/CONDITION:
The vehicle operator may experience a Malfunction Indicator Lamp (MIL) illumination due to the following Diagnostic Trouble Code (DTC): P0524 - Engine Oil Pressure Too Low
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 14, 2012 | 2007 Dodge Ram Truck
How do you reset the service indicator sign on a 311 srinter van 2007 i have serviced the van but the warning lighy wikk not go out can anyone help wiyh the problem thankyou j callaghan
Instructions in hand book will not work.
Currently, the only way to reset ASSYST (the oil change reminder) is to use a dealership scan tool.
Cabin Compartment Node electronic control module reset required.
If you insist on DIY'ing your own maintenance, then you need to spend $2000 or so on a Mercedes Scanner. One compatable with StarSCAN, StarMOBILE, WiTECH or Mercedes-Benz Star Diagnosis System.
These are available on eBay but don't be surprised if it doesn't work !
..........or seek out a local tech' who can do the reset
Jan 12, 2011 | Mercedes-Benz Sprinter Cars & Trucks
Can not get connected
Powercycle (unplug power) all your equipment, Modem/Router waite 15 seconds then plug back in. If you are having an issue with the ip address not valid you can try these steps
(win xp) Start/Run/Type ncpa.cpl hit ok, You will see wireless connection double click wireless connection this will bring you to the properties. ensure that the connection is assigned by DHCP also check to see if you have a valid ip address
Win Vista/7 Start/Search Bar/Type ncpa.cpl Right click on wireless connection and hit properties. Uncheck Internet protocol version 6 and click on Internet Protocol Version 4 and hit properties/Ensure that obtain ip address automatically is checked as well as obtain dns server automatically. hit ok close out.
Go to command prompt Win XP Start/Run/Type CMD hit ok
Win Vista or 7 Start/all programs/accessories/ right click on command prompt and hit run as administrator.
At command prompt type;
netsh int ip reset reset.log hit enter
netsh int ip delete arpcache hit enter
netsh winsock reset hit enter
ip config /flushdns hit enter and restart computer this will reset the ip address hope this helps good luck
Oct 01, 2010 | Computers & Internet
'08 Liberty Limited - Radio won't hold presets
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-006-08, DATED
FEBRUARY 22, 2008, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL
REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE AN UPDATED
OVERVIEW, REPAIR PROCEDURE AND LABOR TIME.
THE StarSCAN® FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM
THE INTERNET.
StarSCAN® SOFTWARE LEVEL MUST BE AT RELEASE 8.05 OR HIGHER FOR THIS
BULLETIN.
SUBJECT:
Flash: Driver/Memory Seat or Driver Power Seat Functions Intermittently
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Memory Seat Module
(MSMD) **and performing calibration on the MSMD with the STARScan.**
MODELS:
2008 (KK) Liberty
2008 (RT) Caravan/Town & Country
NOTE: This bulletin applies to RT vehicles with sales code JT2 and KK vehicles with
sales code LEW built prior to September 21, 2007 (0921XXMDH).
SYMPTOM/CONDITION:
The driver/memory seat and or driver power seat functions can become intermittently
inoperative due to a Memory Seat Module software issue. A software design change has
been made to eliminated these intermittent conditions.
Jul 17, 2009 | 2008 Jeep Liberty
I need to delet my messages fron my phone and i cant it is a nextel i850
Text messages? The voice mails are on a server, not the device. If you cannot delete the text messages try resetting defaults by doing the following:
Press Menu key and scroll to settings (toolbox icon) hit OK button
Scroll down to advanced; hit OK button
Scroll down to "Reset Defaults" and hit ok
Select "Reset Settings" and hit ok
VERY IMPORTANT: DO NOT SELECT RESET ALL- THIS WILL DELETE ALL YOUR DATA INCLUDING YOUR CONTACTS
After selecting Reset Defaults enter security code 000000 and select ok then select yes
You will not lose any data or info stored on the phone. This will simply reset your settings to factory defaults so you will have to reset your wallpaper, ringtones etc...
Mar 18, 2009 | Nextel i850
How to reset my copy counter to my kyocera km-1500
Sorry you cannot reset your counter if you pass the 10,000 copies, if you are under you can, but just to let you know that you can reset the counter only for 1 time, you can do that by entering the maintenance mode of the machine and reset the counter.
hit 1087 twice it let you go to maintenance mode then start touch the screen up or down till you see the counter life reset, then hit start buttom, then highlight the buttom that come on the screen and hit start or reset and u will be fine.
to exit the maintenance mode hit reset buttom twice till you see 000 on the screen, then hit number 1 then start.
Best regards
Mar 01, 2009 | Kyocera Mita Office Equipment & Supplies
Can't set time, etc. on Ottimo Billboard Solar watch.
I just picked up this watch.  Setting it is easy.  Hold down the button marked "RESET" (lower right) until the numbers start blinking.  Hit the "MODE" button (lower left) until the the settings you want to change are blinking.  Hit the "ST/STP" button (upper right) to change that setting.  Keep on hitting these two buttons until the settings are as you would like them.  Hit "RESET" button to finish.  So, to change just the day, I would hold down "RESET," hit "MODE" four times, hit "ST/STP" until the date is correct, hit "RESET" to save.
Dec 20, 2008 | Bulova Watch
Hp laserjet 3500 transfer kit
Hit the check botton on the control panel for the printer. Scroll down to "Configure Device" and hit the check button. Scroll down to "Resets" and hit the check button. Scroll to "Reset Supplies" and hit the check button. Scroll to "New Transfer Kit" and hit the check button. Scroll to "yes" and hit the check button.
Hit the return button (next to check button) until back at ready again. Transfer belt count should be reset now.
To make sure, from the info menu, scroll down to "print suply stus page" and hit the check button. Transfer belt should read as 100% now.
DON'T WORRY IF IT TAKES MORE THAN ONCE FOR IT TO TAKE. WE'VE SEEN IT TAKE 2 OR 3 TIMES OF REPEATING THE PROCESS (for no good reason) BEFORE THE MACHINE RESETS THE COUNT.
Aug 25, 2008 | HP Color LaserJet 3500 Printer
Cell Phones Logo
62 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
