Question about Gestetner F101 Toner FTL1BLK
Fuser error Fax is not working, shows a "fuser error" message
A want to make my printer work it is showing a message (printer fuser temp, will you help me to solve the problem
That error indicates that your fuser is not getting hot enough to fuse the toner to the paper. If you can get to it then make sure all the cable leading to the fuser are hooked up well. If they are and nothing has wiggled loose then the fuser is likely faulty and needs to be replaced.
Sep 20, 2014 | Xerox Phaser 3100MFP
Error messgae
sir i have panasonic fax KX-MB2030 call servic 3 error i try #900* 550 but it is not work
Nov 28, 2013 | Panasonic KX-FL611 Plain Paper Laser Fax
Message showing FUSER ERROR??? Please could you tell me what this error is and can it be fixed?? Thanks Suze
This is a error whit our fuser unit. this the part in front of your fax which is hot. check the bulp inside. if it is ok. check the thermister
Jan 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Says fuser error 50.2 turn off and on? why is this and how do i fox it
This is a hp error for a broken fuser unit. You need to post more info for anyone to give a firm answer, ie make and model of machine and when after power on does the error message show. If you have a HP, then your fuser unit is not reaching temperature by the required time. Most likely the ceramic heating element is blown.
Oct 06, 2010 | Office Equipment & Supplies
The fax shows a messages saying "open heat error"
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
Jul 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
Mita DC1435 Copier shows a C63 error message
you have a fuser code. you will need to test the fuser lamp, thermo fuse and thermistor with a vom with machine umplugged. open the front door and the clamshell. remove the orange fuser cover. t. remove the back cover. remove the bottom black cover. unplug the lamp, and thermistor. go to the fron of the machine. just to the right of the fuser on the frame is a black screw. remove it. now tip up the fuser 97 degrees and slide it to the left it will come out. now test the lamp with ohms, continuity, do the samae for the fuse. you will need ti remove the thermistor with one screw. put your finger onit. put he meter at 200 ohms and it should change vlaue. good luck
Dec 26, 2009 | Office Equipment & Supplies
Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Nov 14, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Gestetner F101 Toner FTL1BLK Logo
15 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
