Question about Vidal Sassoon VSCL828 Hair Trimmer
On off button does not work
Inside the shaver what holds the on off switch in place
Will not turn off
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Was this helpful? Yes No 4 people thought this was helpful
Add a comment
    • davjones101
    • 1 minute ago
    Thanks ,very helpful. Let me just add a vital bit of information On removing front assembly, to remove sliding switch and access spring clip under blue button you have to release locking clip (it's like a long sprung piece of plastic) from LH side by just pushing it to the right with a fine screwdriver etc. It's concealed under another piece of plastic. I also removed inward facig lug on shaver body (under slider) as this snags the metal spring when refixed
    Reply
Oct 17, 2010 | Braun Syncro 7526 Electric Shaver
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
Jul 11, 2010 | Braun Syncro 7505 Electric Shaver
Hello. My HQ7830 on/off switch has stopped
This is a Quadra Action model and this is somewhat common. Most likely, the actual switch is not the problem. More likely, the problem is the plastic post that is between the button you push and the switch inside. Open up the shaver to take a look at it. The clear plastic post is probably either broken and loose inside or has gotten out of position ans is not making contact with the switch.
Replacement parts for this are no longer available so your only hope is to rig the plastic post somehow so that it will make contact with the switch. I've never had any good luck in doing this. It is possible that you may have to replace the shaver.
Feb 22, 2010 | Philips Philishave HQ7830 Electric Shaver
Norelco shaver won't turn off
You should check the switch behind the batteries. You likely dislodged the piece of plastic that presses on the switch. It's simple to place back properly--if that's what the problem is.
Jul 16, 2008 | Norelco Advantage 6705 X Electric Shaver
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Switch is stuck in on position braun 7505
You only need an small screwdriver, pull out the blue button and the metallic part, Ready!. Only one thing, you have to forgett about the aesthetics of the shaver, but it's work perfectly, Thanks a lot!
May 30, 2008 | Health & Beauty
Braun Syncro 7680 Electric Razor
Great instructions.
I left out the plastic latch and the razor works fine. OK with me.
On step "f" there was a little guide on one side...I had to push that in before sliding the switch upwards...it slid right out after doing that.
Thanks...it helped a lot.
Jan 24, 2008 | Braun Syncro 7680 Electric Shaver
Smarttouch xl lock
Keep the on/off button pressed for approx 30sec (or more) until the razor starts
Dec 05, 2007 | Philips SmartTouch-XL HQ9190 CC Electric...
Braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
GOOD LUCK!!
Nov 28, 2007 | Braun Syncro 7526 Electric Shaver
Wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
May 30, 2007 | Panasonic ES 8077S Electric Shaver
Vidal Sassoon VSCL828 Hair Trimmer Logo
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
