Question about Sony PlayStation 2 (PS2) Console
My playstation picture is damage and screw up but the sound still good and the game stil working. the picture spread become alot of small squre and spread away and the colour become awful even gone. plese help me
    Problem Solver:
  • 9 Answers
Its probably the ps2 thats broken because its such an old console just buy a new one they are cheaper than 360 games
Posted on Jun 14, 2009
Ps2 v12 clicking sound
Sounds like the CD/DVD drive is starting to fail.
Jun 27, 2012 | Sony PlayStation 2 (PS2) Console
Panasonic 47 Rear Projection TV
Usually what I find in a case like that is that there is a loose solder joint on the CRT board of the red picture tube. When the connection is good the picture looks fine but when it lets go the picture turns that awful greenish-blue. On most sets the bottom front of the TV will disassemble to allow access to the CRT boards, and the solder joints can be resoldered quite easily. If you do not have experience resoldering boards in a projection TV then allow a qualified tech to handle it for you.
Aug 06, 2007 | Panasonic PT-47WX51 47" Rear Projection...
My ps2 slim is not reading any discs why ?
Hi. Try to clean the lens by using a qtip and alcohol. Here's the procedure on how to clean the lens.
  • 1 Turn the PlayStation 2 over to remove the screw covers. Use the flat head screwdriver to remove the plugs that cover the screws. This reveals several Philips screws. Do not remove them yet. They must be unscrewed in a certain order so that the PS2 opens up properly.
  • 2 Remove the small screws near the control ports, powerboard and DVD drive using a Phillips screwdriver.
  • 3 Remove the long screws from the upper right section. This enables you to remove the cover.
  • 4 Flip the PlayStation 2 over to open it up. Before opening it, ensure the PS2 has had adequate cooldown time. Wait at least one hour after playing the game station before continuing. You do not want to burn yourself on the hot elements within.
  • 5 Open the PS2 carefully so as not to damage the ribbon inside the console. Lift up the case gently and slide the cover off. Notice the big black box that contains the laser lens and DVD drive unit you need to clean.
  • 6 Locate four black, small screws holding the black box down. Remove the screws using a Philips screwdriver.
  • 7 Lift up gently on the cover of the DVD drive. This fully exposes the laser lens.
  • 8 Dip one cotton swab in rubbing alcohol. Gently rub around the edge of the lens with the swab. Look for any greasy residue that may be there and remove it. Remove any fuzz. Use gentle pressure so you do not damage the PlayStation's lens.
  • 9 Take a dry cotton swab and dry off any liquid left behind. Ensure there are no cotton fibers left behind on the lens.
  • 10 Reassemble the PlayStation 2. Work backwards from the way in which you disassembled it.
  • Sep 04, 2010 | Sony PlayStation 2 Slimline Console
    It won't display games that are inserted
    the laser used to read the discs is fried, you need to order a new one from ebay and replace it, alot of the older ps3's have the issue, ive gone through 3 myself in the last few years since ps3 came out. its an easy job to do a few small screws to open playstation and just simply remove old laser unit and replace with new one.
    Jun 21, 2010 | Sony Playstation 3 (PS3) Console
    Sony psp have sound no piture screen not damaged
    you may need to leave it for a couple as the picture inside is running slow so leave it and it should become back to normal sooner then later
    Jan 16, 2010 | Sony PlayStation Portable (PSP) Console
    My sega genesis has picture but no sound
    if you are using a standard coaxial cable, then these tend to get damaged alot, the wires get stretched inside, usualy due to wrapping it around to keep the cable tidy when not in use, try "pinching" an inch of cable together so it forms a small U shape in your finger, now try that all the way up the wire while sound should be working
    Mar 13, 2009 | Sega Genesis Console
    I just got Petz Horsez 2 for playstation 2, only apparently I haven't inserted a playstation disc or a playstation 2 disc. I have a feeling that the game may not work for my type of playstation 2. Is there...
    well the playstation 2 isnt reading the disc. most likely there is a small crack or scratch on the disc. try cleaning it with small amounts of water. to much water can permantly damage the disc
    Feb 26, 2009 | Ubi Soft Entertainment Petz: Horsez 2
    No audio with digitial audio while playing LBP
    little big planet uses almost all of sonys computing power to play alot of other games only uses a small fraction im sorry no fix currently known to me
    Jan 09, 2009 | Sony Playstation 3 (PS3) Console
    Don't even know
    If you try reseting the unit unplugging everything and plugging back in.
    Also , did you receive the 1 year warranty with your unit. I would call Sony and push for a new unit.
    It seems like alot of people of having the same issues with their unit also.
    "Good Luck"
    Apr 29, 2008 | Sony Playstation 3 (PS3) Console
    Ps3
     see hear for more info on how to resolve this http://uk.playstation.com/help-support/ps3/guides/detail/item48646/Connecting-to-your-TV/
    riz.
    Oct 24, 2007 | Sony Playstation 3 (PS3) Console
    Sony PlayStation 2 (PS2) Console Logo
    63 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
