Question about Panasonic WORKiO DP-C262 Printer
Panasonic dp 262
Tranfer belt
I have a Panasonic Workio DPC 262 I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
Intermediate Transfer Belt Length Detection Error Causes 1. Belt Initial Point Detection Sensor is defective. 2. Belt Initial Point Detection Sensor connector is disconnected. 3. EC PCB connector is disconnected. 4. EC PCB is defective. 5. Intermediate Transfer Belt is defective. 6. Intermediate Transfer Belt Motor is defective. 7. Intermediate Transfer Belt Motor Connector is disconnected.
Dec 22, 2014 | Panasonic Office Equipment & Supplies
DP 262 ERROR 04-14 FAN. REPLACED BUT STILL GET THE SAME CODE
Both fans in rear of copier need to be replaced at same time.
Aug 29, 2014 | Panasonic Workio DP-262 C322 OPC Drum 36...
Add developer to dp-262
YOU DONT ADD DEVELOPER, YOU CHANGE IT LIKE CHANGING THE OIL IN YOUR CAR. THIS REALLY NEEDS TO BE DONE BY A TECHNICIAN BECAUSE ONCE YOU CHANGE THE DEVELOPER YOU NEED TO RESET THE COUNTER FOR IT AND DO A DENSITY ADJUSTMENT WHICH REQUIRES A SERVICE MANUAL. GOOD LUCK !
May 04, 2012 | Panasonic WORKiO DP-C262 Printer
Panasonic dp-c262 doesn't network with mac computers.
about the only thing i can think about at the moment is to go to control add printers add by network connection find the printer that is required it should do a connection for you.
im not very good with macs
Apr 01, 2009 | Panasonic DPC262 Printer
Need a reset for the Fuser Web..
You need to go into the f8 mode in order to reset the fuser and anything else you have replaced on the Dp 262
Mar 17, 2009 | Panasonic DPC262 Printer
Problem when scanning with DP 8045
you need to have the latest scanning software "" www.workio.com "" and you need the name and key name inserted in the software
Oct 15, 2008 | Panasonic DP-8045 Grayscale Copier
Panasonic WORKiO DP-C262 Printer Logo
32 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
