Question about Panasonic ES-RT51S Mens Wet/Dry Rechargeable Shaver
Head guard for panasonic shaver
Shaver head guard
  • 14 Answers
SOURCE: wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Posted on Dec 27, 2008
SOURCE: How do I replace the battery in a Panasonic ES8068
I need to know how to replace the batteries, but I don't plan on spending money to find out, I didn't realize your site charged for the answers when I gave you my EMail. I can probably just open up the case and figure it out myself, I just wondered if anyone else hade done it and had any tips.
Posted on Jan 02, 2010
brector3
  • 1610 Answers
SOURCE: have Panasonic ES8093 shaver.charge indicator
this problem is usually from old batteries. batteries will typically lose much of their ability to hold a charge after 3-6 years and they will need to be replaced.
if you use your shaver wet or rinse it under water, I dont suggest that you repair it as you will not likely get it sealed back up well enough to prevent it from leaking.
Panasonic does allow the sale of their specialized shaver batteries to consumers. Therefore, you will need to use a compatible battery type. shaveroutlet.com sells a set here:
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
These are made for Braun shavers but will work because they have prongs on the ends to snap in place like your originals
Posted on Jan 16, 2010
Testimonial: "Thank you for your help Ivor J"
brector3
  • 1610 Answers
SOURCE: Where can I find a
Panasonic does not sell the specialized batteries for their shavers. Your best bet would be to purchase one of the models that replaced it. I have included links to two models below. These are very similar to model ES4011 and use the same shaver head as your model
http://shaveroutlet.com/shavers/panasonic-es-rw30s-mens-wet-and-dry-shaver.html
http://shaveroutlet.com/shavers/panasonic-es4026-shaver-with-er416-nose-and-ear-hair-trimmer-p-699.html
Posted on Dec 16, 2010
Testimonial: "Thank you for the help. Appreciated!"
gavryliuk
SOURCE: How do i change the
Just unscrew a bolt in the bottom, remove two side covers (they are glued but not that much), unscrew two bolts near the head and further two inside. the manual (can be easily found on the web) has this in more detail.
Posted on Apr 07, 2012
New panasonic shaver from u s a,can re7-51 be used with adapter from 240 volt power point
All Panasonic shaver adapters state the acceptable voltage on the 'head' of the plug
May 17, 2017 | Panasonic Health & Beauty
Aternative Shaver Head Frame Holder - HQ9190 Smart Touch ?
There is no way to make the other head holders fit. Sorry
Jul 16, 2016 | Philips Health & Beauty
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
Where can I find a replacement battery for a Panasonic ES4011 wet/dry shaver? I have looked everywhere. THANKS!
Dec 15, 2010 | Panasonic Sonic-2 ES 4011 K Electric...
Panasonic shaver Model ES8068 Linear pulls facial hair rather than cut
panasonic es8068 replacement foil and blades is panasonic WES9079P replacement outer foil and inner blades.
panasonic es8068 replacement blades is panasonic WES9070P inner blades.
Sep 02, 2010 | Panasonic Linear ES 8068 N
Panasonic 8077 shaver top fastener broken
This may sound nutty. Please don't laugh. It works: attach a rubber band from the top "broken" corner of the shaver to the underside. Yup. Lousy design. Are you done laughing yet?
Jan 28, 2009 | Panasonic ES 8077S Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Panasonic ES-RT51S Mens Wet/Dry Rechargeable Shaver Logo
65 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
