Question about Canon for IMAGERUNNER C2020 C2050 C2058 IRC2100 IRC2100S IRC2105
What is error code e000002-0006
Menew bar cant reach and no other function
    President:
  • Canon Master
  • 2,017 Answers
It's a heat rod error code. It can be reset but will come right back untill the problem is fixed.press additional functions, 2 and 8 together, then additional functions again. on touch screen press copier>function>clear>err>ok. if the machine starts up ok, go to additional functions>common settings>energy consumption in sleep mode and set it to high. if it doesn't code again after this the fixing film unit will be ok, if not, replace it.
Posted on Feb 19, 2015
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
I have a code error 47:03 in my hp t770 and i dont know what to do please help me to solve this problem
47 errors are related to the starwheel motor. This is the motor that lifts the bar that the paper passes under, it has little star shapped wheels on it. If you open the main window and look down you will see it. Make sure it is moving properly and there is no paper jammed under it.
Feb 08, 2015 | HP DESIGNJET T770 Printer
Insignia soundbar
I have listed the steps below to assist with programming the remote to your Sound bar. Please know that we do not promise your remote will function with your sound bar. If you have any other questions, let me know at Kimberly.escobar@dish.com!
Visit this link to obtain the code/s to address remote to sound bar: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear AUX button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The Aux button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code and try this procedure http://www.mydish.com/support/program-to-tv-scan-non-basic?WT.svl=leftnav
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 12, 2014 | Televison & Video
Haier SBEV40 sound bar universal remote code
Problem solved. I bought a LEARNING universal remote from Amazon, and it learned the key functions from the Haier original remote.
Dec 03, 2012 | Haier SBEV40-SLIM 2.1 Speaker System - 160...
Hello i cant reach wifi conection on Acer travelmate 4500,its show: ,,The hardware radio switch its off.,,
the error is shown because the hardware was switched off manually. Try switching it on again by holding down the function key and pressing the corresponding function key with the wifi icon on it.
Mar 27, 2011 | Acer TravelMate 2300 Notebook
When I try to install this update, after the progress bar reached 60% it would display the error code 8002f1f9
i dont know what that error code is but is there a blu ray drive connected, I know that the the last 30-40% of an update is the reflashing of the blu ray logic board. thats why updates always go slow then real fast at the last second and if the logic board is dead or not there it gives an error.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Error Code OE and Door will not unlock
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Dec 16, 2008 | Washing Machines
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Canon for IMAGERUNNER C2020 C2050 C2058 IRC2100 IRC2100S IRC2105 Logo
572 people viewed this question
old marine
old marine
