Question about Car Audio & Video
What has caused porsche fault code P0846 - Car Audio & Video
I have jeep liberty 2010 code p0846
A simple Google on that code there.
Feb 08, 2017 | Jeep Cars & Trucks
So what does it mean when my transmitter sensor say p0846? For my nissan sentra that my engine stopped!
po486 Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance, God-Bless! Please go here for detailed info, www.bestride.com/engine-trouble-codes/P0846
Jun 18, 2016 | Nissan Sentra Cars & Trucks
Showing codes C1116 and P0846
code P0846 has something to do with the transmission maybe fluid level is low. and c1116 is the stop lamp circuit is showing a open.
Apr 11, 2016 | 2012 Nissan Versa
FAULT CODE P1372 FIX FOR 2008 PORSCHE CAYENNE GTS v8 4.8L
A lot of issues with that 4.8, customer of mine replaced o2 sensors, 300 or 308 are present also must look after them first Possible fault causes
- Valve(s) of a cylinder stay jammed in large stroke
- Valves of different cylinders stay jammed in large stroke -parity check error
Oct 04, 2015 | Porsche Cars & Trucks
Code p0734 1997 porsche
code p0734 refers to gear 4 incorrect ratio.==causes --wiring--TR sensor/switch--shift solenoids--transmission mechanical fault
Nov 09, 2013 | Porsche Cars & Trucks
2002 Jeep Grand Cherokee Limited P0846 code
Trouble Code: P0846
A/T 2/4 Pressure Switch Circuit Malfunction
Possible Causes:
2/4 pressure is incorrect, or internal transmission faults exist 2/4 pressure switch circuit is open, shorted to ground or power 2/4 pressure switch is damaged or it has failed TCM relay power circuit to L/R switch is open (loss of B+) PCM/TCM has failed
May 16, 2012 | 2000 Jeep Grand Cherokee
I have a 2004 caravan with p0846 and shifts erractic
Trouble code P0846 means: A/T 2-4 Pressure Switch Circuit Malfunction
This possible causes are to be checked to confirm the fault.Thats it. Thanks.
Dec 07, 2010 | 2003 Dodge Caravan
Transmission with codes P0218 P0732 P0733 P0740 P0846 P1790
I agree, this is a lot of codes. I would tend to think this would be electrical, perhaps computer are a loose connection? These trannys I have rebuilt so far usually have a couple of codes related to the problem but not this many - all over the place.
Apr 16, 2009 | Chrysler Town and Country Cars & Trucks
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
