Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Delonghi aircon not evaporating condensate - DeLonghi Pinguino PACL90 Portable Air Conditioner
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
Delonghi DES14 does not collect water
clean the dust off of the condenser in the front or the filter if it has one. no air flow results in overheating and no condensation across the evaporator coil.
May 08, 2012 | DeLonghi Dehumidifiers
My mazda 6 v6 2004 smell oil when starting ventilation
The smell is typical of older Mazda aircon.
Purchase an aircon cleaning spray which is discharged into the aircon system by selecting recirc , cloing the windows for 5 minutes . This cleanses the system which is probably contaminated with bacteria.
Recharging your air con will help as well. The smell is due to evaporate condensed water mixed with sludge and bacteria .
Sep 20, 2011 | 2004 Mazda 6
Bad smell coming from my delonghi pac w130a portable aircon. When i turn on, when air is still warm you get horrible vinegar like smell, when compressor kicks in and air is cold smell disappears Have...
Look for where the condensation drains, it could be stopped up. If it drains into a pan, check it for mold & mildew. Even if it is a wet type to cool the compressor, drainage still needs to happen. Some times it can get moldy if the water sits.
Apr 28, 2011 | DeLonghi Heating & Cooling
Less than year old Quit cooling DeLonghi told
if it stop cooling then there must a problem with evaporator or refrigerant water holder is a receiver before the evaporator and after the condenser try to locate it now
Feb 25, 2010 | Heating & Cooling
Ive got an amcor air conditioner, will it blow hot air aswell as cold,
If it blows hot and cool air, it means that you aircon is
not having an isolation of the evaporator and condenser
air. Please have a technician repair the air leak. Hot air from the condenser must be separated from the cool air
of the evaporator. Hope this will help you.
Jan 04, 2010 | Amcor PLM-14000E Portable Air Conditioner
Hose leak on lower bulkhead
yeah its normal that don't worry about it.Thats condensation from the ac evaporator
Jun 27, 2009 | 2004 Honda CR-V
Cant find drain hole in window air-con
Modern window AC units no longer have a drain hole.
Condensate flows to the area under and around compressor. The heat from the compressor evaporates the water.
Mar 01, 2009 | DeLonghi (DLGPAC400) Air Conditioner
Hyunai A/C Unnit
Yeah, only a qualified or pro aircon tech can replace it. Also the evaporator coil needs to be check for leak. If your unit is still under warranty better call the manufacturer. Anyway, here's how aircon works:
Window air conditioners work on exactly the same principles as a refrigerator or dehumidifier. They have a cooling system that refrigerates the air entering the unit. The moisture in the air condenses on the cold coils and drips into the bottom tray of the air conditioner. The warm air in the room is drawn over the evaporator coil, which collect heat. The heat is conducted into a refrigerant gas. The gas is then circulated to the condensing coils on the back of the unit where it is dissipated to the outside.
Sep 05, 2008 | Heating & Cooling
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
