Question about HP Mini 1035NR Notebook
Bug behind plastic screen cover and loose right side movement
A bug got between plastic screen cover and glass screen and I need to get it out. How can I pull the plastic screen cover away to remove bug?
Also right side of screen moves up and down a little bit like the hinge is not secured correctly.
    Sergeant:
  • 268 Answers
Sadly the entire system needs to be taken apart. There is going to be at least 15 screws to remove and you need to move with surgical precision.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Posted on Jun 19, 2009
Bug behind glass screen
Take and throw it away.
Oct 11, 2012 | LG Televison & Video
I NEED TO KNOW THE LOCATION OF THE FUSE BOX IN A 2008 VW BUG
The fuse panel on 2002 VW Beetle is located behind a plastic cover on the driver's side end panel of the dashboard, door open. See pictures below:
The fuse panel diagram:
Mar 24, 2011 | Volkswagen Beetle Cars & Trucks
How to chang a tailight in a VW Bug
Inside the trunk, behind the tail light, you will see a plastic cover. Open the cover and remove the screw securing the tail light assembly. Then you will have to take a flat object and gently pry on the actual assembly where the assembly meets the body of the car. Use a plastic object as you don't want to wreck the paint. There will be four clips on the tail light assembly holding it into place.
Oct 16, 2009 | 2004 Volkswagen Beetle
Oct 16, 2009 | 2001 Volkswagen Beetle
Bug between screen and plastic cover screen how do i clean
You will have to remove Front cover in order to clean, remove bottom part then you should see screws holding on screen remove and clean
Sep 21, 2009 | JVC HD56G887 56" HDTV
The front screen cover
The speaker cover just pulls off, there are 4 screws holding the screen on, take them out and the screen should lift off. But be careful, there are wires attached to it, so don't let it drop.
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
2000 Bug
Is it not blowing enough air or is the air never getting cold the first may be a clogged cabin air filter a pain to get to need to remove the center and right side of the dash top plus anothe cover to get to it.
Jul 14, 2008 | 2000 Volkswagen Beetle
Removing a screen protector from a Hitachi 50UX58B Projection color TV
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).ea84b4b.jpg
Once this strip is removed, you should be able to see a gap (~2mm) between the top of the protector and the frame. Pull the middle of the protector toward you (you may need to hook it with something like a chrochet hook to get it out to where you can get a finger on it). Pull out one side of the protector, then work it loose fromt he bottom. (If it is stubborn, you may have to loosen the bottom frame. Take of the speaker grill, then unscrew the screw on the bottom of the surround for the control panel and pop the surround out. Then there are 3 screws that hold the cabinet frame {might me different for the 58B} and beneath that, 3 screws that hold the bottom of the inside frame. Once those are removed, you should be able to flex the inside frame enough to loosen the protector.)
Installation is the reverse. There are two grooves (at least on my set), and the protector goes in the rear groove(!) (same as the screen itself - first time I tried to put it in the unused groove closer to the front of the screen, and that iddn't work). The black plastic retainer strip goes in the front groove.
Mar 22, 2008 | Hitachi 50UX58B 50" Rear Projection...
Folding the stroller
There are two latches/triggers. one on each side, under the handle bar behind the canopy. pull up on these and the stroller will fold down.
Mar 10, 2008 | Yakima Bug Jogger Stroller
HP Mini 1035NR Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
