Question about Franke Evolution
Adjust card install number
    Problem Solver:
  • 17 Answers
What do you mean?
Posted on Apr 22, 2014
We've got a new adjust card for our evolution coffee maker (the old one was broken). The machine displays "installation number". What number do we have to type in?
the installation number in normaly the serialnumber. you can find this behind the door of the coffee-outlet or behind the door of the brewing-group.
Jan 03, 2017 | Franke Evolution
I installed my graphics card and no display comes up for either monitor. i am trying to setup dual monitors on my computer. When I try to install while my computer is on with one monitor it freezes my...
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope this helps
May 15, 2011 | EliteGroup ECS N6200A-512DZ-H GeForce...
I have installed XFX GeForce 6200TC 128 Mb card and drivers from the supplied driver disc that came with it. i cannot get it to display dual monitors when i go to windows display settings! can u assist...
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes hope this helps
Apr 21, 2011 | XFX GeForce 6200TC Graphic Card
8985 ibm desktop window xp sound drivers install but some eror hda not found how to install audio drives
First remove the win_xp sound driver u install
restart ur computer
install the corect cd driver of ur sound card it comes w/ the sound card
restart ur computer
check the device manger if ur sound card is corecly installed and adjust the corect settings
play a music
Feb 25, 2011 | Computers & Internet
I can't change my screen resulation. It is stuck on 640X480 {4 bit} I have gone to different web sites to try and download changes, but I still can't get any of them to do the job.
Sounds like you do not have the correct driver installed for your graphics card/chip.
Since you did not mention, did you try adjusting from display properties panel? If not, right click on desktop, select properties, click settings tab and there you will find resolution slider and color depth. Adjust and apply/ok.
If this didn't work try this...
The first thing you must do is identify what graphics you have. This can be done a bunch of different ways but the easiest would to download install and run Driver Detective.
http://www.drivershq.com/driver-update/graphics-video-adapter/
Now I am not really sure if you have to purchase, if it does prompt ignore as it will tell you what video card/chip you have.
Then you can visit makers website (Google name it gives you) and get on their support/downloads web page. Download and install latest driver.
Another possibility....
If this is a Dell/Gateway/Emachine or some other major brand, the companies website will have what you need. They usually have a service code number or go by a serial number. This will get you exactly where you need to be.
And another...
If all else fails in the above you can add a video card IF you have an available slot inside your machine. This is way more complicated but can be performed rater easily.
This should cure your problem.
Feb 27, 2010 | Balance CM2017 17" Monitor
Gateway 5310 series Multi videocard output
The MB video, is automatically disabled when you plug in any other card, accordingly, usually it is "Enabled" when it is taken out. You can adjust the Video RAM size sometimes via the BIOS, though. Now to get the drivers, look on the MB, there will be a set of big, Numbers and Letters, usually white, or black, by one of the slots, that is the Motherboard's identity, or get Everest, a free MB identity program, now, using that number Google, that-number + motherboard drivers, That will get you them, download and install. XP SP2, would be better...
Feb 26, 2010 | Gateway 5310 (1008368) PC Desktop
View sreen smaller than monitor size
Well a few things can be assumed, I think.
You're monitor is a CRT(not LCD - which has auto-adjust), and possibly you've just finished installing windows on that machine, and maybe your video card drivers are not installed.
For this step-by-step, it will likely require that the correct video card drivers are installed.
Lets move on and assume they are fine:
-Right-Click on your desktop, click Properties.
-a Display Properties window will pop up, click Settings(usually the far top-right tab), near the bottom right of the Settings panel is Advanced.. click on it(Advanced)
-what will pop up is "'something' Monitor and 'something' Properties", and from here you'll go to the Monitor tab.
-the setting to adjust is the Screen Refresh Rate. Select a different number, click Apply... see what it looks like, and try a different number if that's not good enough - rinse, repeat.... at least until you get what you're looking for, or close to...
-Then close out all of it.
Beyond that adjustability, the only thing to be messed with is the monitors' vertical and horizontal sizing adjustments, which are only accessible using the buttons on the screen, and how that works will vary depending on the brand & model.
I hope that works out for you
P.S. Avoid un-checking the 'hide modes that this monitor cannot display' ... going beyond the monitors ability will blank out your screen and then you will hafta adjust the settings back, literally BLIND(not very fun in my experiences).
Jan 13, 2010 | Microsoft Windows XP Home Edition
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Installed new video card, system reboots
your current graphics card settings is not set to the correct level to match your system, you can download ATI Catalyst software from this link:
http://support.amd.com/us/gpudownload/Pages/index.aspx
after installing, you may have to restart your computer. when you restart, right click on the desktop and select (ATI catalyst), there you can adjust your graphic card features or you can use the recommended settings the software have adjusted for your graphic card by clicking on restore settings/defaults.
you should not encounter problems once you have installed the ATI software.
Sep 09, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Cant adjust video resolution onboard videocard failed installed jaton trident videocard cant adjust above 800 600 screen resolution
Try downloading the most recent drivers for your new video card from the manufacturers website, that should get your resolution problem fixed.
May 03, 2009 | Computers & Internet
Coffee Makers & Espresso Machines Logo
93 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Yves
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
