Question about Health & Beauty
What does R3E stand for in blood pathology - Health & Beauty
My left leg from knee to toes swells daily at least an inch. I sleep it goes to normal
Swelling of the leg may involve a noticeable distension of the shin or calf, ankles, feet or toes. Foot swelling may be a common occurrence which most of us will experience at some point in life after a long day of standing or sitting but may also be an indication of a more serious pathology as in certain cardiovascular disorders.
Recurrent or persistent swelling of the feet should be investigated by a medical practitioner especially if you have a history of cardiovascular disease or have noticed a change in color, sensation or mobility of the leg, foot or toe.
Blood rich in oxygen and nutrients flows through the arteries to the target area. Blood carrying deoxygenated blood returns to the heart via the veins where it is quickly routed to the lungs to be replenished with oxygen.
Blood flowing to the leg has to return to the heart through a group of veins with intermittent valves located throughout the course of the vein. This venous blood (blood in the veins that is returning to the heart) has to flow against gravity and since the pressure is usually lower at the feet, other muscles of the leg assist with 'pumping' this blood back to the heart. This muscle pump is most active when we are walking and least when we are standing stationary or sitting. Blood travels short distances up the vein and backflow of blood is prevented by a series of valves in these veins.
Working alongside the blood vessels are the lymphatic vessels which return lymphatic fluid (lymph) back up the body to empty into the blood system.
Swelling of the leg usually occurs as a result of an inadequate flow of blood or lymphatic fluid back up to the torso of the body. However other localized causes may further contribute to swollen feet, ankles or toes.
Apr 20, 2017 | Knee Health & Beauty
Is my test done
no
simply because fixya site is not your pathology company
Mar 31, 2017 | Health & Beauty
How low is to low with my blood pressure?
Mayo clinic says: Most doctors consider chronically low blood pressure too low only if it causes noticeable symptoms. (Such as dizziness, especially when first standing up). Some experts define low blood pressure as readings lower than 90 mm Hg systolic or 60 mm Hg diastolic - you need to have only one number in the low range for your blood pressure to be considered lower than normal. I hope this helps!
Mar 30, 2017 | Health & Beauty
I just took my blood pressure it was 111/70 I am 78 yrs. old Is this good or low?
Sounds just about right how do you feel.
Blood pressure is just one indicator of your health I find the more I check the sicker I feel.
If you have a good energy level are eating a good diet don't get dizzy when you stand up or faint or feel like you're heads busting open when you do stand up or move quickly then your blood pressure is probably just fine.
Listen to the signs are body is giving you.
Good luck and stay active.
Nov 22, 2016 | Health & Beauty
What is pearinda plus tablets to treat
PEARINDA belongs to a class of medicines called ACE inhibitors. ACE stands for angiotensin converting enzyme. It works by blocking ACE, an enzyme involved in narrowing blood vessels and causing sodium and fluid retention by the kidneys. This causes blood vessels to relax, allowing blood to flow more freely and at a lower pressure, and increasing the heart's ability to pump blood in some types of heart failure.
source
PEARINDA
Oct 20, 2016 | Tablets & eReaders
What does error EP stand for on the homedics bpa-201 stand for?
According to BPA-201 manual, pages 10 and 31, the "EP error" is a system error. The suggested action for this error, again according to the manual, is "measure again", as can be seen in the figure below:
25799308-fquli33imuwglv45q20hnaoi-1-0.png The manual can be downloaded from:
http://www.homedics.com/media/documents/homedics/instructionbooks/BPA-201_IB.pdf
Hope you may find this answer helpful !
Regards,
Miguel L. Martins
Jul 28, 2015 | Homedics BPA201 Automatic Arm Blood...
Why won,t my sores heal on my arms or buttocks ?
Best to check with your doctor. It is not recommended to apply creams without analyzing the pathology of the sores. You might need a simple diet change and not any creams. Sometimes these are allergies or blood related rather than superficial skin eruptions.
Sep 21, 2014 | Miscellaneous
Are the wrist monitors accurte for checking blood pressure while exercising?
Only if you're standing very, very still and not huffing and puffing from being out of breath.
Apr 28, 2011 | Walgreens By Homedics Automatic Blood...
Health & Beauty Logo
159 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
