What is a network adater - Computers & Internet
Sino ang kasama ko
Please do clean the head your VHS by using special head cleaner and check also your VHS mechanism and ensure it working well. If still problem, your VHS head is defective and suggest to replace with new one Regards, Jay
Dec 24, 2010 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
Tip
When Using ADAT with Digidesign Interface (Fix pops & clicks)
When you connect a device (a lightpipe optical ADAT for example) to your audio interface such as the Digi 003 be sure to change the "Hardware" settings in the File Menu, from internal to optical, and ADAT for using for using an optical ADAT device, such as the M-Audio Octane. This will stop the pops and clicks that happen when the clocking is not set for ADAT.
on Dec 08, 2009 | Digidesign 003 Rack Firewire Audio...
How do i turn on the wirless network adator
To turn it ON you must press the Fn+F1 keys together
Apr 20, 2010 | Fujitsu AMILO Pro V1000 Notebook
How so i expand the outputs on a motu using adat
You have to goto motu audio/midi setup an config the optical output to adat and make sure you set the sample rate to 48000 and check your setting in audio/midi setup in your system preference under mac this should solve the problem.
Dec 08, 2008 | Motu Traveler (8250) Audio Input
Help
You just need to look at the wireless adater and find the model number and
then download the driver from the page under the correct model.
http://www.opendrivers.com/
Jun 07, 2008 | Computers & Internet
Adaptor
I am looking for adator (Dc/c.c. in 6V) for my Quasar palmcorder VM_L153-D, also A/V adator, . I will also like to down load the manual for this product
Feb 03, 2008 | Quasar VM-L153 VHS-C Camcorder
Alesis lx20 type 2
send it to be serviced.
My adat lx20 keeps showing a error 2 and spits the tape back out, i chek the tape in my other adats and its fine. any suggestions?
Owain
Dec 24, 2007 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
Bluetooth
if they both have blue tooth adaters then you need to make a new network conection for the pair
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 23, 2007 | Compaq Evo N610C Notebook
Tape torn near end. How to fix????
You'll have to open it up, but be very careful doing this. It can be done though, with a steady hand.
Nov 11, 2007 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
Computers & Internet Logo
10 people viewed this question
David Payne
David Payne
