Question about Miele Dishwashers
How long does did take to replace a miele heater relay
Error code f51 flashing. What's wrong?
David: Try downloading this free user manual: http://laundry.manualsonline.com/manuals/mfg/miele/pw_6065.htmlk According to ApplianceHelponline.: " Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Background information:
Start position: One second after the program start, heater relay K1/1 is activated. This enables a check as to whether the contacts on heater pressure switch B1/13 have closed on switching steps 21/22 or 11/12.
Cause:
Heater relay defective; contact open.
Remedy:
Replace the heater relay.
Cause:
Heater relay solenoid defective.
Remedy:
Cause:
Connection from heater relay to electronic module open-circuited.
Remedy:
1. Check plug connections.
2. Check the connection wires for continuity.
Cause:
Heater pressure switch open- or short-circuited.
Remedy:
Replace the heater pressure switch.
Cause:
Connection from heater pressure switch to electronic open-circuited.
Remedy:
Cause:
Foreign objects in heater pressure switch.
Remedy:
Replace the heater pressure switch."
May 14, 2015 | Miele Washing Machines
What is Technical Fault 51? It appeared a few moments ago on our machine, but when I switched it off and reset the machine it worked as normal again.
F51 Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Apr 14, 2015 | Miele Washing Machines
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
F11 blocked inlet/drain
f11 error code says in the manual
Drainage fault
Water present in appliance and is not being drained off. The display shows
Drain fault F11. The buzzer is activated for 2 minutes.
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning. Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
this is usually caused by a blockage in the drain but can also occur from other circumstances as listed above you can also see this at this link as well http://appliancehelponline.com/miele.html
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks again Rick
Jun 07, 2011 | Miele Dishwashers
Dishwasher miele g2582scvi fault code f25
Check this out.
F25 Desired temperature fault At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
1. Check the heater relay solenoid.
2. Check the heater relay solenoid voltage (12VDC) from the electronic.
3. Replace the electronic, if necessary.
Cause:
Excess quantity of detergent or rinse aid dispensed. Excess foam has developed.
Remedy:
Check the dispensed quantities of detergent and rinse aid. Follow the information given in the operating instructions F25 Desired temperature fault At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
Cause:
Remedy:
Mar 15, 2011 | Dishwashers
Getting a F51 message
F51
Start position:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
if you have any further questions message me back and please remember to rank this opinion it allows me to help people in similar situations in the future Thanks again Rick
Jan 23, 2011 | Miele Dishwashers
What does F24 mean on my Miele dishwasher readout?
f24 is no signal from the heater relay. at the start of a cycle the dishwasher runs the drain pump for 30 seconds. it will, at the same time send a power signal to the heater relay. if the computer doesnt see a signal back from the relay, it will stop the cycle and beep. Sometimes this happens almost as soon as you press the start button. Sometimes the relays are just bad, but it is usually caused by a voltage spike, or by using too much detergent. the excess detergent will oversuds the machine, and leak into the bottom pan. the soap will corrode the contacts on the relay and cause the f24 fault. the relay can be accessed by removing the bottom pan of the dishwasher with 4 t20 screws. it requires that the dishwasher be turned on its side.
Nov 19, 2010 | Miele Dishwashers
Miele Dishwasher does not start
hi,
F51 fault is more than likely the heater relay is faulty but it could be your circulation pump is jammed up. if you are confident you can easily replace the replace the relay if it is faulty. you would need to put a meter across the terminals. if it is ok then the pump is blocked. if you are not confident you would require a service call. Miele have there own deadicated service team if you live in a metro area
hope this helps.
Mar 30, 2010 | Miele G892SC SS Dishwasher
I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
Aug 24, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele G520 dishwasher
goes open circuit when temp is reached.
if you are getting no heat, then look at the heater relay
Oct 20, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
32 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
