Question about Health & Beauty
What cause high potasium - Health & Beauty
2 Suggested Answers
guyster7148
  • 192 Answers
SOURCE: I just started on a
I checked with my own Dr, I am a nurse on the payroll, he told me that you should be fine..... There are no reasons to take the med as well as the Airbourne, it is for a short time. If you have a blood pressure cuff, continue to take the meds and check the BP and make sure that you are in line, but if you dont, it would be recommended to get one anyway as you are now on a beta blocker for the BP. Be well and stay healthy, doing great!!! Guy
Posted on Sep 10, 2010
What caueses low potasium
Hi Susan,
Here are some common causes for low potassium:
  • Antibiotics.
  • Diarrhea or vomiting.
  • Using too much laxative, which can cause diarrhea.
  • Chronic kidney disease.
  • Diuretic medicines (water pills), used to treat heart failure and high blood pressure.
  • Eating disorders (such as bulimia)
  • Low magnesium level.
  • Sweating.
Jan 05, 2017 | Cars & Trucks
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Causes of price fluctuations in agricultural production
High costs passed on i/e: seed, labor, fertilizer, irrigation, transportation, interest rates, bad weather, new equipment
Low yields & low competition, cause increased prices
High yields & high competition cause decreased prices
Aug 29, 2013 | Ultraviolet Heat Shield Covers For Causes...
My HC (PPM) WAS HIGH AND THE NO (PPM) WAS HIGH WHAT IS CAUSING THIS? SO I DID NOT PASS SMOG THANK YOU
An old worn out engine will have high emmisions due to burning oil. Also, with age, a catalitic converter won't burn up any fuel vapors causing high emmisions.
Sep 11, 2010 | Isuzu Rodeo Cars & Trucks
I just started on a medicine for high blood pressure,Lisinopril. The warnings are not to take a salt substitute while on it, potasium being the concern. I am just getting over a sinus infection and usually...
Sep 10, 2010 | Health & Beauty
What would be the cause for high pressure on a hayward cartridge in ground system even after the filters are clean and I'm talking 30#
number one cause is the filters no good anymore.... things like high ph over a looong time can cause filter clogging...
another cause could be a heater causing excessive "head"...i.e its backed up as well
if your running a caretaker system (jets that pop up on the floor) they can cause high head as well.... make sure your returns are adequately opened
May 20, 2010 | Pool & Spa
P1487 manufacturer control auxillery emission controls
High Speed Fan Control Relay Circuit ,try this.In a nutshell, wiring problems come down to only a few possible causes, and they are:
1. Open circuit (or partially open such as a chaffed line which causes high resistance due to heat when circuit load is on)
2. Short to power
3. Short to ground
4. High resistance (usually caused by corrosion or poor connections)
Oct 07, 2009 | 1998 Mitsubishi Eclipse
Idles to high
You may need an Idle Air Control Valve (a common problem), I would also change the thermostat as well. If its reading cold it will cause the car to idle high.
Apr 13, 2009 | Toyota Camry Cars & Trucks
TRUCK BLOWS A LOT OF HEADLIGHTS...BOTH SIDES, ANY IDEAS WHERE TO START
usually due to high resistance causing high voltage. Check voltage at headlamp. should be between 12 & 14 volts.
check headlamp grounds. if loose or corroded, it will cause high current draw.
Mar 10, 2009 | 2006 Dodge Ram 3500 Truck
Health & Beauty Logo
93 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
