Question about Waring Wine Chiller - Black
HITACHI CHILLER KX-R31AM TRIPPED
LED 3 LIGHTS WHEN OVER CURRENT PCB IS ACTED (20A)
Power indicator just keeps blinking
H16 on this model means that either the power supply transformer has failed, The outdoor PCB has failed or the machine is low on gas.
This info is from the Panasonic service guide. The outdoor unit LED 1 is on, LED 2 is on, LED 3 is off, LED 4 is off.
H16 On On Off Off Current Transformer Problem Power Transistor Module or Outdoor PCB Faulty. Very Low Gas
Mar 28, 2014 | Panasonic Heating & Cooling
What does E1 error code on a Karda heat pump, model KSAC-18HRDCI mean as there is nothing in the manual about error codes. How do you clear it?
I have worked this out. There is a 20A fuse inside the compressor(outside) unit, it is a glass fuse that has a sleeve over it and is soldered to the PCB. They appear to have a manufacturing fault and 'blow' at a lower current than the 20A, Just the edge of the fuse link is not properly bonded to the end cap. On inspection they don't look blown, but test open circuit. Was a relatively easy fix with a soldering iron and a new 20A fuse. You can find this fuse on the gas piping end of the compressor.
Sep 12, 2011 | Heating & Cooling
Our york MAXE screw chiller tripped on CONDENCER-HIGH PRESSURE-STOPPED when i want to reset means it asks password,what is the password
My chiller was high pressure trip and i cannot reset the fault using 9675 and 1380 passcode! What should i do ?
Nov 24, 2010 | York Yankees Bedding MLB Comforter
Honywell whine chiller model 88058 not working
Hello friend, i had the same problem and it was solved replacing largest capacitors on board, they are 2 x 120uF(120V). You must to check that both original capacitors be damaged, you can to see it if they are inflated on the top
Jul 23, 2010 | Honeywell Consumer Products Model...
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Panasonic KX TG2237 - Handset lights up but displays message "no connection to base unit"
Unplugged and reinstalled all components. In the process I discovered a GFI circuit had tripped. When I reset the circuit breaker all was well. Problem solved.
Jan 06, 2010 | Panasonic KX TG2237 Cordless Phone...
Blown fuse in stereo amp
well fuse get burnt when there is heavy current flow than the fuse rating so there is heavy current flow and this current flow might be because off short circuit in the PCB and this short circuit might be because of any transistor breakdown so u have to check through the PCB.(Printed Circuit Board)
Jan 05, 2010 | Audio Players & Recorders
Mitsubishi HD1080
Good Day;
You may have a bad lamp. What lights show on front panel? Check this when no come on:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A .
Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No link to base
check your handset.. reheat or resolder the components at pcb.
Aug 15, 2007 | Panasonic KX TC1703 Cordless Phone
Waring Wine Chiller - Black Logo
73 people viewed this question
Top Waring Home Experts
Donni Steen
Tom Chichester
Are you a Waring Home Expert? Answer questions, earn points and help others
