Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have an old 15hp gamefisher that's not getting fire
Have u got spark ? Put new fuel in flushed carb and fuel lines ?
Posted on Mar 18, 2014
Install ignition points on 9.9 gamefisher
remove flywheel remove old points and install new set. set gap ,replace flywheel,
Oct 21, 2014 | Light Outboard Motor Boat Bass Fishing...
How do I hook up a 15hp kohler engine to a 13hp lawnmover
will bolt holes physicaly fit ? if so then bolt to frame and i suggest using blade from new mower on old frame
Oct 15, 2014 | Kohler 15HP Replacement Engine SV470-3200...
How to disconnect gear shift lever on a 1996 gamefisher 15hp outboard
usually where the lower unit splits midway if you look inside you will see a couple screws or bolts remove one then it can be pulled apart.
Oct 06, 2014 | Boating
How do i remove and reinstall the propeller pin on an old gamefisher electric trolling motor? mode# 217-590093
remove the prop theres a carter pin in shaft replace it put it back together
Aug 29, 2013 | Boating
Does my 1997 gamefisher 9.9 require a thermostat ?
You have this in the wrong section, this is car and truck problems.
Jun 14, 2012 | Cars & Trucks
I would like to know how to test a solid state,magneto
with a spark tester .some motors require an external resister on the solid state units
Mar 28, 2010 | Boating
I bought a 5 HP gamefisher outboard motor. It 's been use once and then it sit for years outside. I change the spark plug,clean the carburator,fuel filter looks good.good compression. gas go all a way to...
If spark plug is dry, fuel is not getting to the cylinders. Next thing to check would be the fuel pump... Gas may be getting to carb, but the pump needs to push it into the cylinders too.
Oct 18, 2009 | Boating
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
May 05, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
113 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
