Question about Home
Ge range model jbp45as1ad turn on oven
Stove top burners all work, has power to all heating elements, tested oven elements for continuity checks good
  • 1314 Answers
SOURCE: Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
Posted on Mar 31, 2008
SOURCE: GE P7 Oven 2 burners out on stove top
Purchased a new stove.
Posted on Dec 27, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 10865 Answers
SOURCE: Oven not heating properly
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Posted on May 26, 2009
    TheMazz
    • 78 Answers
    SOURCE: heating element stays on when turned off
    The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
    You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
    If you would like to see a wiring diagram...click on this link:
    http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
    If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
    Posted on Oct 15, 2009
    Thermador SCD302TP oven not working at all. First the fan turned off then the whole panel went blank while the oven was on and never came back. Checked the plug and brakers. What could be wrong.
    Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
    1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
    2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
    3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
    4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
    5.
    6.Even a bad relay door switch will hinder your oven from operating.
    If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
    THINGS TO CHECK:
    the broil element
    is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
    If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
    The bake element
    is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
    Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
    The oven safety valve
    (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
    I offer free advice bcuz God is so good!
    Surface burners
    are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
    You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
    On modern electronic control ranges, the oven temperature sensor
    is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
    The infinite switch
    on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
    1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
    2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
    3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
    4.Repeat the step above for the terminals "L2" and "H2".
    5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
    6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
    7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
    If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
    Most modern ovens use an electronic control board
    to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
    The oven burner igniter
    commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
    http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
    https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
    http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
    Jan 11, 2017 | Thermador Ovens
    Venini oven not heating up
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Jan 03, 2017 | Ovens
    Whirlpool oven W10233413 oven won't heat up
    https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on- Oven Won Turn on Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Jan 14, 2013 | Whirlpool Ovens
    WHIRLPOOL SF262LXSB OVEN NOT WORKING
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
    Nov 06, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
    Power cut and now my whirlpool akz451 will not heat up
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Oven Won Turn on
    Aug 27, 2012 | Whirlpool AKZ159IX Oven
    Whirlpool model #WFG114SWQ0
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Aug 15, 2012 | Whirlpool Ovens
    Whirlpool accubake oven not heating
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Jul 06, 2012 | Whirlpool Ovens
    Whirlpool akg668/wh oven not working
    http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    May 18, 2012 | Whirlpool Ovens
    F9EO comes on the control panel, nothing works.
    5.
    THINGS TO CHECK:
    the broil element
    The bake element
    Surface burners
    The infinite switch
    Jan 05, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
    GE glass top and oven are not heating?
    I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
    Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
    Home Logo
    477 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
