Question about Lotus Elise Alarm Siren Oe 2005 2006 2007
My 2006 lotus elise turns over but wont run, I dont know if there is a alarm problem?
Its the flex compasitor located on the exhaust intake manifold its right behind the oil pump.. GReen Switch on/off hope this helps
Posted on Aug 26, 2009
  • noneya49 Aug 26, 2009
    jdfnkwdf
Who have lotus elise 1.8 engine code k16engine ecu wiring Diagram
You just go to the link I attached I'm sure you will get the solution of your problem
lotus elise
Jul 10, 2016 | Lotus Cars & Trucks
My Lotus Elise turn signals and hazard lights are not working. IS there anything I can check before taking it to the dealer?
Check fuses. Have you by any chance changed to LED bulbs? If so, flasher units must be changed as the new bulbs draw less current. If bulbs not changed, might try changing flashers anyway as they are cheap. These should be located in the fuse box for most cars.
Dec 18, 2014 | 2005 Lotus Elise
Looking after supercharged elise in garage - went flat so charged battery, now won't start and there is a circular ring on the speedo just above centre - what is this?
If the alarm was on, when the battery went flat - and I suppose it was - then you have to follow the manual to teach in your keys again.
Jan 23, 2013 | 2005 Lotus Elise
Resetting the check engine light
You need a OBD2-device for that.
Aug 18, 2012 | 2006 Lotus Elise
Repair manual lutus elise
I find this sites with information about your question:
- Lotus Elise - Workshop Manual Workshop Manuals
- 2005 Elise - Owners Manual (PDF Format)
- Lotus_Workshop_Manuals
Hope helps, and, remember to rate this answer.
Feb 02, 2011 | 2001 Lotus Elise
Lotus elise s1 non starter - suddenly
HAD THE SAME PROBLEM IT TURNED OUT TO BE THE CAM SENSOR AN EASY FIX
Nov 09, 2009 | 1999 Lotus Elise
Elise
where is the leak from sounds like brake or clutch fluid as oil is coloured. Check the level of the brake/clutch fluid reservoir in the front of the car it is a common reservoir supplying both. the slave cylinder fo the clutch is located on the gear box in the engine compartment left hand side towards the bulkhead on a large black steel bracket these are the most common componets to leak. easy to change and not very expensive.
Aug 14, 2008 | 2005 Lotus Elise
How to start it
press the large button on the key fob to imobilise the alarm system then try the start button
Jun 27, 2008 | 2005 Lotus Elise
Lotus Elise Alarm Siren Oe 2005 2006 2007 Logo
241 people viewed this question
Top SEAS Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a SEAS Vehicle Part and Accessory Expert? Answer questions, earn points and help others
