Question about Dell Inspiron Computers & Internet
I have a dell inspiron 5521 15R can you explain the hard disk partitions
Using disk manager I see EFI system Partition OEM partition tree Recovery partitions a C partition and a Primary partition
    Top Expert:
  • Dell Master
  • 22,107 Answers
You will find this interesting reading;
http://www.win.tue.nl/~aeb/partitions/partition_types-1.html
Posted on Mar 18, 2014
SOURCE: System recovery
I am having this same problem with my laptop holding down zero as in instructed by the manual does nothing and neither does f-11 any ideas? also the "HDDRECOVERY" partition does exist.
Posted on Jan 22, 2008
SOURCE: Dell Inspiron 1525 Partition
Vista as other OS have a limitation on partitions, for Vista is 4, so you cant add another one.
The easiest solution is you to backup your recovery partition and then delete it.
You can use "Ghost" or other similar programs to copy that partition.
Posted on Mar 29, 2009
mnelsonix
  • 58 Answers
SOURCE: how to recovery the system from recovery partition
Did you know you only get ONE shot at creating a recovery disc? And most of the time it is garbage, just like Vista.
He tried to put XP on it and failed? weird.
A couple things you can do...
1. Get your hands on a Vista disk. If you know anyone that works in IT, you can borrow a Vista disk. Do a complete fresh install. Use your "Product Key" and you will have your own Licensed, perfectly legal version of Vista.
2. Get yourself a copy of XP. Delete all partitions, then create a new one. Don't try to save that Vista recovery partition...it's toast. I recommend XP, but I'm a dinosaur.
Posted on Apr 07, 2009
bootz84
  • 197 Answers
SOURCE: I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
Posted on May 04, 2009
haayz
  • 197 Answers
SOURCE: Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
Posted on Jul 01, 2009
Reformat partition hard drive
To return your HD to the factory settings do a full system recovery using the recovery disks (CD or DVDs) you made when you first had the computer. This will return the whole computer to its as-shipped state: you will lose all your data and any software that you have installed. This will retain/re-install the original partition structure on your hard disk. To do this process you may also use the recovery partition on the hard disk.
To completely reformat the hard disk, in which case you will lose everything on it
press the start button at the bottom left of screen,
R-click on computer, and select manage. The computer management window will open. From the left pane click on disk management under 'storage'. A new pane will open, with information on the different disks in your computer. Select the disk on which the partition to be formatted is located. R-click on the partition to be formatted, and choose format, and ten work through the format wizard. (see http://windows.microsoft.com/en-us/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7)
When you R-click on the partition other options will appear will appear as well as format, choose the appropriate option to create a new partition, merge, etc, By successively working your working your way through the partitions you may format/merge some while retaining others.
18.July.2014
Jul 11, 2014 | HEWLETT-PACKARD Computers & Internet
Unble to formate the pendrive
Free Partition Software - MiniTool Partition Wizard Home Edition home1.png MiniTool Partition Wizard Home Edition is a free partition manager software designed by MT Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista and Windows 7. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions, Copying partitions, Create partition, Delete partition, Format partition, Convert partition, Explore partition, Hide partition, Change drive letter, Set active partition, Partition Recovery.
Dec 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hi, I am owning a dell inspiron 1525 for the last 3 years now. Few days ago when i was formatting my laptop to install a new OS, i accidentally deleted a partition and it became unallocated. My hard disk...
Startup from the windows 7 disk as if you were going to reinstall. Choose 'advanced' in the section where you sort out the disk to install to, and partition the unallocated space. Then exit out, do not continue to the format and install stage.
Once you have restarted into your original windows, you can format the new partition as normal.
Having said that, 10gb is pretty small for an OS partition, 15 0r 20gigs would be better and you can swap some space from your new partition to the OS partition. There are plenty of tools you can use to do this with at www.download.com.
Aug 29, 2010 | Dell Inspiron 1525 Notebook
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
Mar 23, 2010 | Computers & Internet
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
I have installed a 100gb hard drive in an inspiron 1100 laptop but i can not partition it so i can install windows can you help
To partition your notebook inspiron just look up on this link:
http://hotfile.com/dl/18652627/27cc92a/Utility.DVD.2009.Final.TC.part01.rar.html
I hope this will help you. Enjoy...
Dec 09, 2009 | Dell Inspiron 1100 Notebook
I don't recommend just partitioning with an active system.(only when you are reinstalling or installing your OS for the first time) The reason they have multiple partitions is for reinstall/recovery.  You can right click on My Computer and click manage.  Click disk managment to see more details about partitions.  If it is an UNLETTERED partition leave it alone.  I use partition magic (it's not free) There are free ones but you get what you pay for.  Partitions are touchy with the possibliity you ruin your MBR and need to fdisk and reinstall windows.  Be sure you know what you are doing.
James Mac
Sep 08, 2008 | Dell Computers & Internet
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
