Question about Chanel CH 4164 Sunglasses
Need screw 4164 b screw for channel sunglasses
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
Missing screw
Any local optical shop should have a aftermarket screw for these
Feb 07, 2014 | Burberry Clothing Accessories
I HAVE A PAIR OF BURBERRY SUN GLASSES THAT SCREWS KEEP COMING OUT OF. I NEED TO KNOW WHAT CAN BE DONE .I HAVE TRIED PUTTING SCREWS IN BUT THEY KEEP COMING OUT.
sounds like the threads worn pop the screw in and with a pin head apply superglue otherwise take into any glasses shop and they should be able to help please give thumbs up thanks
Aug 09, 2011 | Burberry Clothing Accessories
Chanel CH 4164 Sunglasses Logo
51 people viewed this question
Top Chanel Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Chanel Clothing Accessory Expert? Answer questions, earn points and help others
