Question about Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator
Freezer fan make a noise once in awhile
I have been own hotpoint refrigerator for 2 yrs now,but recently it start making a noise from freezer fan for about 20 min and noise are gone after then, what is the problem ?
  • 232 Answers
I have had some suces with removing the fan motor and soaking the BEARING AREA ONLY with # 10 w oil. the housing around bearing has a spong like material that feeds the bearing oil as it needs it if it only quiets down for a short time just get a new one a motor that is good luck
Posted on Jul 01, 2009
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My refrigerator/freezer making a howling sound and an intermittent whirring sound. I have noticed this at night, not sure if it is doing this during the day.
I have the same model, and the exact same problem. Additionally, the compressor/fan for the freezer cycles up and then down (rising and falling noise pitch) at a frequency of about every 5 seconds. The howling is worse at night(!?). It is 4 yrs old and was in the house we just bought. Help quickly, or this is a CraigsList item.
Thanks
Jan 12, 2010 | Hotpoint HSS25GFP Side by Side...
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fan oscillation
Probably damaged the fan blade. If plastic, it could be missing a blade or maybe cracked. If metal, probably bent. I would ttry to get an eyeball on it while it''s running to see just what's up. Fan motors are usually pretty durable and last quite awhile.Good Luck and hope this helps.
Mar 15, 2009 | Hotpoint HSM25GFRSA
FAN IN THE FREEZER DEPT MAKING NOISE MAYBE FAN
if the fan is making noise it can also due to dust collected in the fan winks towards it end.or the other option is motor getting weak and needs replacement.
Feb 20, 2009 | Hotpoint HSS25GFP Side by Side...
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint  16.6 Cu. Ft. Top-Freezer Refrigerator Logo
255 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
