Question about Kenmore 63942 Dryer
I want to strait wire my dryer element - Kenmore 63942 Dryer
    Habit-Forming:
    New Friend:
  • 82 Answers
Do not straight wire the dryer element unless you are trying to burn down your house?
Posted on May 22, 2014
Whirlpool Dryer is not heating
suspect element. refer to wiring diagram. unplug dryer. unscrew or unplug wires from element. use multimeter set to "continuity," and touch leads to ends of element where you removed wires. If no meter reading or "beep," element is probably bad. If you have continuity, suspect loose wires or switches. That's all I know!
Apr 14, 2013 | Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
Dryer not getting hot
First ck and make sure you have 220 volts to the dryer. It will run on 110v if one side of the breaker is bad. The other culprits are a limit switch heating element or thermal fuse. If you have 220 volts and the dryer runs just does not heat first turn off the power to the dryer and unplug the dryer from the outlet. Pull the dryer out and remove the lower back panel it is held on by several 5/16 hex screws. (not the back plate on the switch panel) Remove the back and your heater is on the lower right hand side and is inside an metal shell. The thermal limit is also on the metal shell and will have several wires running to it. And if you trace the wires from the element and this thermal limit it will go to the thermal fuse it is on the lower back slightly to the right of the dryer and has two wires run to it and is about the size of a dime or smaller. Unplug the two wires from the termal fuse and hook them together with a papper clip or just tape them together make sure it doesn't touch metal. (this will short it out) and then plug up the dryer and try it to see if it heats you do not need to hook up the vent. (make sure not to touch the back of the dryer and especially any exsposed wires. If it heats up your thermal fuse is bad replace it. If it does not you should check your heating element first unplug the dryer and reattach the wires to the thermal fuse. Then the heating element metal shell should be removed. First unplug the wires to the heating element and thermal limit switch and mark them so you know where they go. Next remove the screw at the top of the metal shell pickup and pull back on the shell to disengage it from the dryer. You can then remove it and inside is the heating element it is attached to the shell with 5/16 hex screws. Remove the screws and pull the heating element out of the bottom of the metal shell. Look closely and you should see the heating element break. The element is a coiled wire and when it heats up the wire actually grows in length and when it is off it cools and shrinks this causes fatique and the wire breaks over time. If the wire is broke replace the element. Look very closely use a pencil to move the wire slightly it is sometimes very hard to see the break. If broken replace the element and make sure not to touch the new element with your fingers this can case premature hot spots which causes the element to fail prematurely. If the wire is not broken then the thermal limit attached to the metal shell that holds the heating element is bad. Before doing any of the above you should look at all the wires in the back of the dryer and look for burnt or broken wires replace or repair them and check the dryer before any other repairs should be entertained. Before replaceing the back on the dryer clean all of the lint out of the back of the dryer and out of the dryer vent. This is very good insureance for the future of your dryer. Good Luck and I hope this is useful.
Sep 28, 2010 | Kenmore Dryers
The old element has 3 wires the new element only
You need to take the high limit thermostat off of the old element. It sits over one of the terminals of the heating element, and has two termnals on it. It should just be one screw to take it off.
Dec 05, 2009 | Roper REX4634KQ Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
I am changing the heating element in the dryer but am not sure which wire goes where
are there 2 or 3 wires going to the element if there are 3 wires the neutral wire goes to the center connection or "mid-point" of the element connection if just 2 wires then hook up either wire to either terminal
Sep 19, 2009 | Whirlpool GEW9250 Electric Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Roper dryer will not heat after replacing element
did you ck the thermal fuse located at top of element housing it may be blown..also if you have only 1 wire to element other leg of element should be attached to lower thermostat by a wire or short metal connector
Nov 15, 2008 | Dryers
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore 63942 Dryer Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
