Question about PowerPro Power Pro C639 98-06 Vw Air Pump 078906601d Beetle Cabrio Golf Jetta Passat Audi A4 A6 S6 Tt Allroad 98 99 00 01 02 03 04 05 06
I have a 2005 VW Beetle, the horn has started going off on its own
Where is the fuel filter located on a 2005 VW Beetle?
Hi under the car at the rear on the rhs of the fuel tank.
Sep 26, 2014 | 2005 Volkswagen New Beetle
2000 vw beetle horn not working
It might have a bad connection. It could have something inside of it causing the problem. It might be dismounted. The most likely cause of the problem is either the horn is bad, or it has a short or a loose connection. Repair car by using the tools @http://www.obd2express.co.uk
Oct 19, 2012 | 2000 Volkswagen Beetle
The radiator warning light blinks red on startup, what kind of radiator fluid does the vehicle take? 2005 VW new beetle
VW have their own spec anti freeze/coolant, but any good quality upper market anti freeze can be used and some will even say that they are recommended by VW. Follow the directions on the container for mix and dilution.
Feb 04, 2011 | 2005 Volkswagen New Beetle Convertible
I have a 2005 VW Beetle Convertible. the engine
Very bad.Sorry but you need of engine overhaul.Again sorry
Jun 19, 2010 | 2005 Volkswagen New Beetle
2005 Beetle Convertible top leaks
bad idea as water in a vacuum unit burns out the motor
go to a vw service center and have them show you where the drain hose is an d clean it out on a regular basis
Sep 08, 2017 | 2005 Volkswagen New Beetle Convertible
Fuse box diagram for a 2000 vw beetle
There should be a diagram in your Owner's Manual. I have one for my daughter's 1998 Beetle that should be the same as in the 2000 Beetle. Can email it to you if you post an email address that I can send it to.
Jun 11, 2009 | 2000 Volkswagen Beetle
Horn Problem
All VW's have electrical problems sounds like a relay switch isn't working properly or you have a serious eletrical problem. And if's a 1.8 turbo boy are you in for a headach. That cars a nightmare I know cause I've worked on these cars and VW won't recall any of them. Best thing to do is try to fix it and dump it.
Mar 16, 2009 | 2001 Volkswagen Beetle
1999 vw beetle
my beetle is fairly stubburn....for example: i tried cranking it with the alam going off and after five times the alarm cut itself off, then i started it and drove off. but that clearly is no valet over-ride because the second and third time didnt work. second time i unlocked the hatchh back and the assenger door and started the engine and it worked. third time....well...still trying.!!
Jul 25, 2008 | 1999 Volkswagen Beetle
PowerPro Power Pro C639 98-06 Vw Air Pump 078906601d Beetle Cabrio Golf Jetta Passat Audi A4 A6 S6 Tt Allroad 98 99 00 01 02 03 04 05 06 Logo
62 people viewed this question
Top PowerPro Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a PowerPro Fish Expert? Answer questions, earn points and help others
