Question about Exercise & Fitness
Trotter cxt plus will power and count down but after one the belt won't start it just says error
5 Suggested Answers
SOURCE: The trotter cxt plus powers on and says saftey
I ran into the same solution. After quite a bit of fooling around we figured out that you have to push and hold the start/stop button and while holding you push the cycle button. Up that helps.
Posted on Nov 25, 2009
ercupa190
  • 12223 Answers
SOURCE: carol lewis mot566 error code 03
1)probably a faulty speed sensor
2) speed sensor is not plugged in properly.
3)possibly a faulty motor
4) Main control board or lower board.
The error codes will differ between makes and models but could be e1.
Check this video for speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
adjust the speed sensor:Move the motor to slacken the pulley, then lift the motor to get underneath. That is where the treadmills speed sensor will be located. It is usually a square or rectangular shaped green module with connectors at both ends.
Finally after you did the adjustment you can conclude:
A) Faulty Speed sensor B) Main Motor faulty C) Main Motor Controller faulty.
attached block diagram for treadmill that I did for any treadmills,see how the Main Motor Board has function for 90% of the treadmills.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Nov 23, 2011
ercupa190
  • 12223 Answers
SOURCE: when i start it up..it counts down from 3 ..then the belt starts to move then stops and shows the error codes H3 , 13, 24
Proceed with the Lube maintenance, the problem is symtom from lack of Lube.
Read the instruction manual, for maintenance, if you do not have download for free: www. fitness.manualsonline.com or www.iconservice.com or www.manualsfactory.com
sincerely. God bless you
Posted on May 08, 2012
ercupa190
  • 12223 Answers
SOURCE: Download Trotter CXT Treadmill manual - where?
go please to www.fitness.manualsonline.com or www.iconservice.com
God bless you
Posted on Jul 02, 2012
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
How do I move a trotter CXL Plus out of the house?
It does take a lot to take it apart.
I suggest you fold it up and get a fridge cart or something with wheels on it and take it that way. Ours has wheels on one end of it and to get it down some stairs we get three or four strong men to help.
I know they are heavy.
Feb 18, 2015 | Exercise & Fitness
HOW TO FIX ERROR 3 CODE ON TROTTER CXT
unplug it then leave it unplugged then you won't see that error message.
Terry
Jul 17, 2014 | ErrorExpert Computers & Internet
Dryer won't spin belt good
Your problem says dryer but the category says washer. I wrote this answer thinking the problem was washer. Sorry but I haven't had opportunity to fix my dryer before so can't help you there. If however your problem is the washer (or is anyone else is reading this), please read on... you should find some ideas here.
First you have to check the error code. If your washer does not have a digital display you have to do the following:
1. press any button to "wake up" the machine.
2. press and hold the start and pause buttons.
3. count the flashing lights.
a) first the five lights plus the start light will flash. Count.
b) then the start light will flash. Count.
4. error code is E +# of times in a + total # of flashes in a and b.
Example: flashes start light plus all five lights 4 times, then a pause, then start light alone 3 times. Error code is E47.
There are lots of error codes but E47 and E43 are both door problems. Check out the following document for a lengthy (but understandable) troubleshooting guide. E47 and E43 both say to do Test 9, which is test the resistance of the PTC. If it's not working then you have to replace the door latch assembly (about $80), if it reads around 1500 Ohms you have to replace the control board (about $250).
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf
First, let me say that I have no idea how to test the PTC but it can't be hard with a standard multimeter (I will be doing this tomorrow with my Dad).
Second, the removal to access the door latch assembly is stupid easy - check out the following YouTube.
http://www.youtube.com/watch?v=prkM2XMoOJk
Third, if you have a different error code just look up the test in the manual document above.
Hope that helps!
Dec 15, 2012 | Frigidaire Affinity ATF7000E Front Load...
God bless you
Jul 01, 2012 | Exercise & Fitness
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
The trotter cxt plus powers on and says saftey then it does not let me continue. I purchased it used and it did not come with a owners guide. Is this a simple fix? My other tread mill needed a magnetic key...
Oct 26, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
