Question about Mtxstw Side To Top Mount Battery Posts
How to convert a side posts battery into a top posts battery
  • 35 Answers
Adapter kit from auto store
Posted on Mar 18, 2014
The cords on each side of my convertable are broken how can i fix this problem can the top still go down
Tonya, Check the attached links, you can also search the internet for top repairers in your area.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Convertible Tops
VW New Beetle Convertible 2003 2010 Convertible top outer shell remove...
https://www.convertibletopguys.com/sitemap/view/107/volkswagen-convertible-top
Convertible Top Side Tension Cables
Mar 05, 2016 | 2005 Volkswagen New Beetle Convertible
Convert battery cables from top post to side mount replacement ends?
If all you are doing is changing to a side post battery, just connect all the positive cables from the old pos post to the new pos holder and all the neg ones to the new neg holder. If you've already cut them all off and not sure where each wire goes, all the reds are positive, all the blacks are neg. To make sure use your continuity meter to test. Connect one meter lead to any good clean metal part on the car and test between each black wire in turn, the neg ones will show a circuit, the pos ones will not.
Feb 10, 2015 | 1993 Chrysler Concorde
IS THE BATTERY A TOP POST OR SIDE POST IN A DODGE AVENGER
A quick look under hood should answer this. If no battery, check cable ends for which type.
Dec 29, 2014 | 2008 Dodge Avenger
I need to change the battery
it depends if it is top post or side post, another words wheather the cables connect to the top or side of the battery. side post are usually 5/16 the top post are usually 1/2 make sure to remove the ground first so not to short anything out. good luck
Aug 10, 2012 | 2004 Pontiac Sunfire
How to convert from side post to top post
there are screw in posts for side post batteries sold at most auto parts stores, but they come out of the battery horizonially-these are common imn marine applications as well.
Apr 15, 2011 | 1999 Oldsmobile Alero
Turn ignition key everything goes dead
Ive had this one before on my avalanche, What it ended up being was a loose / dirty battery terminal. The side post batterys are know for this, you can convert it over to a top post. It will fit tight, but it will fit. Benifits, from this is more starting power and etc. If its not your battery terminals, check the chassis ground coming off the motor to the frame. If its not that, check the positive connection on the starter, then if your starter is "hot" I suspect the starter has failed. hope this helps
Aug 07, 2010 | 2000 Chevrolet Silverado
92 lebaron convertable. When it rains, the top
If you out the top down, on the windshield side posts you will see a small drain tube on each side. When these cars age the sealant used around the drain tubes rends to get crushed and distorted and tends to cover these tubes not allowing the water to drain down the A posts. This causes the water to back up and run down the inside of the A post and under the dash and onto the floor. It's also possible that the window seals are in need of replacement or adjustment.
Jul 29, 2010 | 1992 Chrysler Lebaron
1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
Apr 13, 2009 | Ford Tractor 8n Front Emblem
Mtxstw Side To Top Mount Battery Posts Logo
19 people viewed this question
Top MTX Televison & Video Experts
Electro Med Services...
Are you a MTX Televison and Video Expert? Answer questions, earn points and help others
