Question about Water Heaters
Bosch aquastar a125b piezo wiring diagram
One side of Piezo wireing goes to Igniter but i don't know where the other lead goes.
  • mike misko
    mike misko Mar 19, 2014
    That is to say the push button striker has two leads, the positive goes to the igniter ,the negative is loose and not attached with no connector of any kind on the end. Can anyone tell me where it should be attached?
  • Water Heaters Master
  • 5,089 Answers
Piezo igniter only needs 1 wire to cause spark.
The other wire might connect to electronic gas control to report error, but brand type and age of product is not described in question.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene h
Posted on Mar 19, 2014
motor1258
  • 6674 Answers
SOURCE: Dsi flt after trying to fire 3 times piezo works
Try removing the safety cut out (looks like a resistor in a plastic sleeve going to thermostat terminal) . Just disconnect it at both ends and connect the female spade from power wire directly to thermostat male terminal where the cut out was connected and try it. If it works, replace it when you get a chance. That protects system in case of flame jumping up in that area due to problems or spider webs etc. Once it's been tripped, it's no good. If that's not the problem, try cleaning your ends of your electrode, and make sure they are in front of flame when burner ignites, as it also act as a flame sensor. Let me know how you make out.
Posted on Jun 21, 2010
  • 67 Answers
SOURCE: Why won't my pilot light? It has been connected
There could be air in the gas line..just follow the instruction on the unit these unit always never give any trouble to ignite.. if you still having problem get a qualified technician to light it..
Posted on Aug 12, 2010
  • 122 Answers
SOURCE: The piezo igniter clicks but the pilot will not
are you getting spark out of it? when you click it can you see a small electric spark? if you see it spark, then the thermocouple will probably need replacing
Dplumber
  • 119 Answers
SOURCE: The Piezo Ignition switch has
Yes, but it is not recommended under any circumstance. Rheem
Posted on Nov 07, 2010
SOURCE: roblem with the Bosch 1600H-NG
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 05, 2011
No spark visible through mica glass inspection cover when piezo igniter button is operated.
Piezo igniters can fail for a few reasons. Often they short or spark in the wrong place. Sometimes they can be corroded. Try cleaning it and see if it will spark. Otherwise, you might need to replace it or just use matches. Is your heater under warranty?
Jun 11, 2015 | Water Heaters
Bosch aquastar 125b
Thermocouple which on that model can be just the Thermocouple or a larger loom with the thermocouple in it depends. Call or look up Houseneeds.com they have parts.
If it was the magnet you wouldn't get any gas to manually light pilot.
Jun 06, 2014 | Water Heaters
Self igniting hot water heater won't reset.
Today's water heaters have sealed combustion chamber and piezo igniter.
If igniter is bad, then water heater will not light... replace igniter.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene h
Mar 31, 2014 | Water Heaters
I have a bosch aquastar aq 125fx probably 9 to 10 years old it heats fine but after about year 2 it stopped working when you fire it up shortly or immediately after firing it up before. in other words it...
You either have a weak spark from your ignitor which needs replacing, a bad elec connection to the ignitor, or it needs to be repositioned nearer the burner. Check connections and try repositioning it before you install a new on.
Apr 30, 2017 | Bosch & Tankless LP Hot Water Heater
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
BOSCH error codes:
Mar 05, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Jun 21, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The piezo igniter clicks but the pilot will not light
Jun 15, 2010 | Fasco Bradford White Hot Water Heater...
Kenmore waterheater piezo innotor won't re-light
air in the line, disconnect the pilot supply and hold the button until you smell gas coming from the valve, that will remove the air, as for the igniter, test it by removing the connection and hold it about 1/8" away from the conenction and click it, should see a spark
Sep 16, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
122 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
