Question about Taco SR503-4 3 Zone Switching Relay
Navien combi boiler
Randomly runs of of hot water. Shower for 5--7 minutes with hot water than goes completely cold. Turn off water. Wait 3 minutes or so. Hot water is back. Does not happen every shower. Sometimes happens at kitchen faucet after less than a minute of hot water.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Call in a plumber. it sounds like it is malfunctioning.
Posted on Mar 18, 2014
WHEN MY NAVIEN COMBI BOILER GOES TO DOMESTIC USE THE AIR HANDLER DONT SHUT OFF UNTIL IT GOES BACK INTO HEAT MODE DONT KNOW WITCH 2 WIRES TO BRING TO THE NAVIEN WITCH HAS A SPOT NEXT TO TT SAYS A/H
I don't see the above problems being of help because it's not a heat pump or a issue about a fan switch. This is a stat and system wiring issue.
Here's a link to a proper wiring diagram.
https://www.dropbox.com/s/808zsozmkxce7fu/CH_NCB%20AHU%20Wiring.pdf
/uploads/images/when-navien-combi-boiler-goes-domestic-34752482-3-1.jpg
Dec 07, 2014 | Heating & Cooling
Water fluctuating hot and cold on a shower run off a combi boiler
could be a number issues 1 the hot and cold water supply going to shower could be of unequeal pressure thus the fluctuating 2the heat exchanger in your boiler is conjested with debris 3 the gas bed in boiler is cross burning giving an unbalanced "heat pick up"out put !2 &3 would apply if your on a combi boiler system .if your on a conventinal system you could be pulling air from the head of the cyclinder ,
Jan 19, 2011 | Home
My shower is run off a combi boiler and recently started to go cold for a couple of seconds every few minutes and nobody is running water elsware in the house.
Check the hot water flow at the shower - if it's as good as other taps the boiler diverter valve is suspect. Replace either the complete valve or the internal rubber diaphragm, depending on the boiler make
Mar 29, 2010 | Home
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Taco SR503-4 3 Zone Switching Relay Logo
332 people viewed this question
Top Taco Electronics - Others Experts
Are you a Taco Electronics - Other Expert? Answer questions, earn points and help others
